Compressor Start-Up From Settle Out
  • guestGuests
  • 0 posts
Posted 02 April 2010 - 12:59 PM
I have motor driven compressor which cannot start from the settle out conditions because the motor is not designed for. Is it possible to open the suction shutdown valve to allow the pressure to reduce to the normal suction pressure before start-up?
Your input is highly appreciated.
#2 ankur2061
ankur2061
  • Forum Moderator
  • 2,484 posts
Posted 02 April 2010 - 10:52 PM
babox75,
I don't see how your query is related to "Relief Devices" but you have still posted it in the Relief device forum. Would you kindly consider posting it in the rigth forum.
  • guestGuests
  • 0 posts
Posted 03 September 2010 - 05:19 AM
hi,
For the situation as you have mentioned, it is common to have a depressurising provision with the compressor loop (at the compressor discharge).
You can definitely utilise the suction shutdown valve (to open), provided the suction system has provision to depressurise the compressor loop pressure from settle out pressure to near suction pressure.
Provision of suction throttle valve, very close to the compressor inlet flange, can also be thought about.
regards,
Arap
#4 fallah
  • 5,026 posts
Posted 03 September 2010 - 10:46 AM
Depressurizing,in the above system,would normally be done through BDV on compressor discharge line.SDV'S already have been closed in order to isolation of the compressor.
