Surface Aeration In Wastewater Treatment Plant
Posted 03 April 2010 - 06:15 PM
Posted 04 April 2010 - 04:06 AM
This is rather a matter of "Strength of materials", so Mechanical/Civil Engineers could be consulted if it is not a preliminary estimate. General way out can be as follows.I would like to know what the ratio between vertical shaft diameter and impeller diameter Or in another world how to calculate shaft diameter if you know impeller diameter , power and rpm
1. Find torque from power and rotational speed, also applying some safety margin. Torque=Power/(2*π*N), N=rotations per second.
2. Estimate max bending moment on the shaft, from literature (1). Cantilever shafts can develop high bending moments close to their connection to the speed reducer.
3. Based on above, estimate moment of inertia of shaft cross section. Shaft is usually a pipe, not a full cylinder (1).
4. It is also recommended to check the system against the possibility of resonance (1).
I have followed this procedure for cost estimates in phosphoric acid tanks (with a vertical agitator each) in 1978-79, based on Reference (1) being a series of articles in "Chemical Engineering" magazine (title: Agitation...). The articles (probably dated 1977) explained the above in sufficient detail for preliminary application, using fps units.
I cannot remember more, but above procedure seems reasonable. It is noted that shaft diameter does not depend only on impeller diameter.
Edited by kkala, 04 April 2010 - 04:17 AM.
Posted 08 April 2010 - 12:09 PM
Edited by kkala, 08 April 2010 - 12:10 PM.
Posted 08 April 2010 - 12:56 PM
anwar,
Try and get the following. This is a solved problem for calculating shaft diameter:
12.7 Shaft Design for Turbine Agitator
Chapter 12, Liquid Agitation
Handbook of Chemical Engineering Calculations, 3rd Edition, Nicholas P. Chopey
Hope this helps.
Lpg Plant DesignStarted by Guest_betulche_* , 08 Mar 2026 |
Air Separation Plant DesignStarted by Guest_adda_* , 03 Mar 2026 |
Surface Area Calculation For Blowdown Orifice Sizing Including FinnedStarted by Guest_victortheone_* , 17 Feb 2026 |
Benfield Solution For Ammonia PlantStarted by Guest_Chemist Ahmed_* , 03 Dec 2023 |
