Dear Engineers;
I want to know in a liquid pipeline if the solar radiation effects on temperature of liquid at the end of the line,
If yes how it has been considered in software like Hysys , Pipe phase….
thanks
The Effect Of Solar Radiation On Pipeline Temp.
Started by afi, Aug 30 2010 05:19 AM
Posted 30 August 2010 - 05:19 AM
Posted 01 September 2010 - 05:07 AM
Afi,
Yes it does. Typically solar radiation in middle east countries in the open desert could be as high as 940-950 W/m2 . Just like heat loss from a hot pipe to to the surroundings here the case is reverse. The pipeline gains heat due to exposure to solar radiation. All pipeline simulators take into account the ambient conditions for performing pipeline thermal analysis. Ambient conditions include the thermal conductivity of soil (for buried pipe), wind speed, heat transfer coefficients (U) for the surroundings as a manual input or calculated by the simulator.
However, whatever little work I have done on pipeline simulators (HYSYS and PIPESIM) I never needed to specify the solar radiation values as an input since most of the pipelines I encountered ran buried and thus no effect of solar radiation.
But principally solar radiation will play a role in aboveground long distance pipelines.
Edited by ankur2061, 01 September 2010 - 05:07 AM.
Posted 05 September 2010 - 12:06 PM
In Greece solar radiation is conservatively taken as 1 kW/m2 (similar value to ones suggested by Ankur) for the safety studies. In the design, supposing that liquid has ambient temperature, design temperature of steel bare pipes is usually taken as 70 oC due to solar radiation. For plants / refineries, I think this can be reached only when fluid is stagnant.I want to know in a liquid pipeline if the solar radiation effects on temperature of liquid at the end of the line,If yes how it has been considered in software like Hysys , Pipe phase…
I do not know whether Hysys etc consider this factor. Temperature rise could be estimated assuming a heat flux onto the external pipe area (insulated or not), yet there may be more practical methods for it.
For stress analysis design temperature is considered (70 oC or 10 oC do not seem to make a difference in steel pipes).
Pipe Fluid Temperature Increase Due To Solar LoadingStarted by Guest_HeemeshJ126_* , 06 Apr 2016 |
Determining Pipeline Design PressureStarted by Guest_applepe_* , 05 Dec 2024 |
Effect Of Continuous Blow Down To Boiler Feed WaterStarted by Guest_Dyames027_* , 21 Nov 2024 |
Energy Saving In Pump By Reducing Pressure Drop In Downstream PipelineStarted by Guest_Srinivas Agastheeswaran_* , 19 Nov 2024 |
Steam Condensate Pipeline Water HammerStarted by Guest_kaidlut_* , 06 Sep 2024 |
