I'm facing an issue when calculating centrifugal compressor power: discharge temperature as calculated by the method stated in GPSA (Eq 13-37, 2004 edition) is around 30% higher than that calculated by HYSYS. Below is the input:
Gas inlet properties:
Molecular weight: 35.68
Mass flow rate: 816,480 kg/hr [1,800,030 lh/hr]
Temperature: 46.1 degC [114.98 degF]
Pressure: 13.79 bara [200.01 psia]
Z factor: 0.8665
Cp/Cv: 1.241
Polytropic efficiency: 0.781
Discharge pressure: 44.82 bara [650.06 psia]
The discharge temperature as per GPSA is 154.8 degC while HYSYS gives 118.7 degC.
Attached please find the .zip file containing an excel file conforming with GPSA and an .hsc file for HYSYS calculation.
Anyone please help explain the big gap. Thank you.
Comp_.zip 34.22KB
278 downloads
Edited by vne, 23 December 2010 - 08:46 PM.
