Dear Senior's
I am a Final year Mechanical Engineer. i am facing problem for calculating Pressure drop of a helical coil pipe line (in subject Power plant Engineering).
I went through net in this regard and found nothing useful. only got how to calculate length of pipe required etc is there any direct relation to calculate the pressure drop in the coil coz i think there will be more of losses as as the flow direction is changing........ So the pressure drop will be more as compared to stright pipe line.!!!
Any help please
Helical Coil Pressure Drop Calculation
Started by pavan.misra1, Jan 01 2011 02:47 AM
Posted 01 January 2011 - 02:47 AM
Posted 05 January 2011 - 06:40 PM
f(coil) = f (straight pipe) *(1+3.5*(d/D))
f = Moody friction factor
d =inside diameter of the coil tubing
D= Diameter of the helical coil
Reference Matthew J.Realff & Jde T sommerfield
(Georgia insitute of technology)
hope this helps
hope this helps
Pressure BuildupStarted by Guest_Yankee_* , Yesterday, 05:31 AM |
Spray Dryer Nozzle Issue – Pressure Increase And Fines IncreaseStarted by Guest_Ella2365_* , 24 Mar 2026 |
Surface Area Calculation For Blowdown Orifice Sizing Including FinnedStarted by Guest_victortheone_* , 17 Feb 2026 |
