Hysys To Excel Converter
Posted 10 January 2011 - 03:47 AM
thanks
Posted 14 January 2011 - 10:42 AM
i want to convert my simulation into excel but got to know that it requires either of these tool aspen simulation workbook or workbook dump or hysys stream reporter...these tools are available on aspen support weblink but as a student i cant download it as it requires registration...so any body know a link to download any of them please share or if has any of these tool upload somewhere from where i can download
thanks
Dear,
Had you been searched here in the forums, you would have got the following link where you can find most of the Hysys-excel automation files. Here you go,
http://www.cheresour...07-hysys-excel/
Posted 24 October 2011 - 02:38 AM
Posted 12 March 2012 - 01:27 AM
I'm Venezuelan, but I will write in English because I see that basically all written in English except for some post.
Then they attached a very practical example that serves to initiate the process Hysys-Excel.
This is an excel file in introducing some parameters (yellow cells), and pressed the button that is located there, the button runs a macro that sends the data from Excel to Hysys and returns the results to HYSYS a cell in excel.
For this particular case, HYSYS returns some physicochemical properties.
In order to run the application requires HYSYS is open, and created a document in HYSYS stored in the same folder where you saved the Excel file. The Hysys file must be named "Ejemplo HYSYS-Excel"
Also must be activated HYSYS library, this is done by pressing "Alt + F11", you enter "Tools" and then "References", once there, proceeds to activate the library, just search for "HYSYS" and check the box.
In the folder where you install Hysys is a "HELP" with all the description of the terms of Hysys library in Visual Basic.
Hoping be useful,
Posted 12 December 2012 - 07:59 AM
Posted 20 May 2013 - 02:12 AM
Dear Padmakar
The Hysys Work Dump attachemnet in the repective Link is not working. Can u Please add the File , so that it will help me to extract Hysys data in Excel Sheet.
Can you also suggest me an alternate method to Extract Hysys simulation file to Spread sheet Format!!
Santosh nandigana
Edited by sannandigana, 20 May 2013 - 02:13 AM.
Teg Regeneration Hysys HelpStarted by Guest_connex_* , 17 Jul 2025 |
