Hello Every One,
I hope you all are fine, I am final year student in ChemE and need some short of help in my Final Year Project work.
I have given to design the plant for extraction and purification of Castor Oil from Seeds.
I want some references to refer and wanna know about the latest techniques recently use for this type of Operation,
please help me out.
Thanks in Advance,
Krunal Shah.
Castor Oil Manufacturing Plant
Started by Krunal Shah, Jul 04 2011 09:06 AM
Posted 04 July 2011 - 09:06 AM
Posted 06 July 2011 - 12:40 AM
Although you may have traced most of them, some probably useful references can be:
-wikipedia for general castor oil knowledge:http://en.wikipedia....wiki/Castor_oil.
-castor oil extraction & purification (no flow sheet):http://www.castoroil...extraction.html.
-castor oil general, including preparation (no flow sheet):http://botanical.com...c/casoil32.html.
-castor oil general info (advertisement?):http://www.castoroil...erivatives.html.
-grades and derivatives:http://www.keloth.com/castoroil.html. Also http://www.kisanagro.com/main/. Market and grades should be known to specify grades to be produced by the plant.
-brief castor oil processing (you may be able to ask more data):http://www.servotech...r-oil-complexes.
-paper for experimental extraction using C7H16 as solvent:http://ljs.academicd...g/A08/43_52.htm.
-castor oil extraction plants, data on request:http://www.troika-so...ion-plants.html.
-special product from castor oil (ogiri), but Figure 2 briefly includes castor oil extraction by words (then it proceeds to fermentation):http://www.pathogenc...esentation.ashx.
-mainly production countries and markets: http://www.modioilmi...20080424_02.pdf.
-castor oil is mentioned by N. Shreve "The Chemical Process Industries" (Chemical Engineering series, MacGraw-Hill), probably not extensively:http://books.google....epage&q&f=false.
-If I remember well, Smith (Chemical Engineering kinetics, MacGraw-Hill) presents an example of acetylated castor oil.
-castor oil plants brief info (probably can get more):http://www.chemchina...stor_oil_plant/.
No flowsheet drawings have been traced, but above can give the process picture; then you can develop the specific flow sheet and dimension the equipment. Hope of good realization of your task!
Edited by kkala, 06 July 2011 - 01:00 PM.
Posted 08 July 2011 - 08:42 AM
Thanks a lot..
Dattebayo..!
Dattebayo..!
Lpg Plant DesignStarted by Guest_betulche_* , 08 Mar 2026 |
Air Separation Plant DesignStarted by Guest_adda_* , 03 Mar 2026 |
Benfield Solution For Ammonia PlantStarted by Guest_Chemist Ahmed_* , 03 Dec 2023 |
Syngas Plant SimulationStarted by Guest_kaidlut_* , 28 Jun 2025 |
