New Rubber Linned Storage Tank For Phosphoric Acid Import
Guest_Attyub194_*
Posted 26 November 2011 - 02:50 AM
We intend to construct a 8000 tons Phos acid storage tank for import of acid . The acid typical specifications are as follows:
P2O5 content 54 %
Al2O3 0.27 %
Fe3O4 0.4 %
We are successfully using carbon steel tanks with rubber lining. Normally, the tank are constructed as per API-650 code
Presently, we have 10,000 tons tanks with ID =30 m and height = 9.0 m and three side mounted agitators
If any one is using 7000 to 8000 tons tank, please advise what is the diameter and height ? Also, please let me know whether agitators are side mounted or vertical
Please also share the name of EPC contractor
In case of space limitation is there a possibility of using larger length to diameter ratio especially for Phos acid storage tank due to installation of agitators
Best regards
Posted 26 November 2011 - 04:35 AM
If the tank were not used as settler, we would install a vertical agitator, since experience of side agitators on ~400 m3 lead lined tanks (for phosphoric acid) was not favorable. They often leaked from the rotating axis, which had to be tolerated, otherwise tank had to be emptied to repair it. Observed spots of accumulated gypsum on tank bottom was another disadvantage, probably curable by increasing RPM (but not tried). In fact we replaced side agitators with a vertical one on one tank, with satisfactory results.
The smaller the tank diameter, the better for the vertical agitator, concerning agitator capital cost and power consumption. For long tanks like the first one, blades at different heights can be investigated.
Blades of said scraper had stainless steel (~304L) cladding, vertical agitator could be similar.
Posted 26 November 2011 - 05:25 AM
Most large capacity tanks and specifically when you have side mounted agitators have very low L/D ratios, may be as low as 0.25-0.3. For a great discussion on tank L/D ratios refer the following link. Also the second last post in the link has an excel sheet for standard dimensions of vertical storage tanks.
http://www.cheresour...3969#entry33969
For knowing more about side-entry agitators for large storage tanks refer the free spreadsheet at:
http://www.cheresour...rs-large-tanks/
Guest_Attyub194_*
Posted 27 November 2011 - 11:33 PM
Good day!
I really appriciate anwsers by my friends. Actuaslly, In API 650 eleventh edition the maximum capacity of tank, Shell courses and Diameter versus height is given for Atmospheric tansk used for Petroleum Services. Phos acid storage tanks are build on the same code.
However, to my knowledge L/D = 1.16 is the maximum used for Phos acid tank due to use of vertical agitators and baffles used for vortex breaking despite API 650 provisiion for having L/D = 1.5 for 12 m dia tank
As per information available on internet 02 tanks of 7500 to 8000 tons are built on Manglore Port . If abny one have length , dia and agitator infomation abale please share.
best regards,
Ahmed Attyub
Edited by Attyub194, 27 November 2011 - 11:35 PM.
Guest_Attyub194_*
Posted 27 November 2011 - 11:37 PM
The leakage at the axis of agitator is the common problem and is over came by using carbon bricks
Best regards,
Ahmed Attyub
Posted 28 November 2011 - 04:59 PM
Data by Ahmed, combined with Ankur's attachments, provide useful information on tank design. Not only total spent steel increases with excess height (after some optimum), but also soil loads require more sophisticated foundations (like piles to touch rock). Of course the above is not limited to API 650. The question is whether it is worth while leaving API 650 (if it does not have a "window") and design long tanks by another code, having a reason for it (e.g. space limitation).
Apart from mentioned phosphoric acid decanter, other long tanks are alumina plant precipitators (dia 14 x height 29.3 m, http://www.cheresour...h__1#entry49756). So long tanks with vertical agitator are used in Chemical Industries, probably because small diameters make vertical agitation easier (*).
One impeller per shaft height = tank diameter can be placed, but good dispersion of gypsum in the acid is needed, or avoidance of pipe clogging? In mentioned fertilizers, phosphoric acid feed was taken from those 400 m3 tanks, whose side propellers rather swept gypsum from bottom (in vicinity of pump suction) that created an overall suspension. In some fertilizer types extra gypsum slurry was added, while other types required decanted acid.
Use of carbon bricks to prevent side agitator leakage was not applied at that time, can Ahmet give some more details? Leaks come out from the "seal" (what kind?). Carbon (that is graphite?) bricks are placed where? It can be an interesting solution to a problem rather caused by suspended solids.
Side agitator leaks were not seen in Refineries. Tanks there seem to follow API 650 dimensions, no vertical agitators have been seen.
(*) This seems to be also true for modern low energy vertical agitators, such as those used in precipitators (EKATO, Robin, Lightling).
Edited by kkala, 10 December 2011 - 03:42 PM.
Guest_Attyub194_*
Posted 11 February 2012 - 09:21 AM
Good day!
Sorry for the delayed response.
The carbon bricks are not used to prevent any leakage, it is used to avoid damage of the floor rubber lining by direct impact . In vertical agitaror same is controlled by allowing a safe distence from the bottom of the tank to the first impeller, however, same is not possible with side mounted agitators.
With respect to leakage, I would like to share my experience regarding operation of Milton Roy agitators that we have never faced leakage problem over my professional carrier. To install a side mounted agitator you just need a flange in the wall of tank and you can easily install the agitator.
As far as the design code is concerned , both vertical and side mounted agitator vessels are designed as per API-650. The design of vertical or top mounted agitator vessel is more tedious as the vessel have to bear the load of agitator static as well as dynamicload and thrust on the walls. On Phos acid storage service I have seem a failure due to improper hydraullic design resultng in breathing of tank cources close to impeller despite the tanks was with open top i.e. with out any roof.
Just to share the finding on Phos acid storage tank , please note the following:
1- Side mounted agitation is always preferred choice, however, to design the storage tank L/D ratio can not be less than 0.3 and there is always a limit on height
2- Vertical mounted agitator requires lesser dia and if there is a space limitation vertical agitated vessel is the preferred choice
However, the hydraullic design need to be confirmed or provided by the agitator manufacturer, who provides all the details of baffle arrangement, dead volume, safe distance of impller from bottom, protection of tank bottom if required
Afterward, design can simply be carried out on ETANK or TANk by COADE
Regrads
Guest_Attyub194_*
Posted 11 February 2012 - 09:28 AM
Good day!
Do any one have experience of using Stainless Steel Tank for Phos acid storage for commercial Phosphoric acid
Best regards
Posted 11 February 2012 - 11:08 AM
1. Side agitators (on 400 m3 tanks) could not provide distribution of gypsum solids in the acid so good as the vertical agitator. The phosphoric acid reactor had a lot of small vertical agitators, resulting in a rather homogeneous slurry.
2. Vertical side agitators (Plenty) are used in a local refinery without leakage, so I suppose suspended gypsum particles destroy the side agitator seal causing leakage from phosphoric acid tank.
3. For vertical agitators, the series "Liquid agitation" of Chemical Engineering was of real help, referred in http://www.cheresou...reatment-plant/.
4. All local phosphoric tanks seen were without cover. The vertical agitator installed on 400 m3 tank was not supported on the tank, but on an independent frame. The scraper on the ~dia 12 m x H 25 m settler was probably independently supported too.
5. Concerning materials, mentioned 400 m3 tanks were internally covered with plumb (construction ~1962).
Scrapper blades were probably of 304 L, but this is not sure (hence written above ~ 304L).
A small phosphoric acid tank was supposed of 316 L for cost estimate, one year ago.
It is not easy to be certain about the material, since commercial phosphoric acid corrosion strength depends on its impurities (HF, SiF4, etc) varying according to phosphate used and the process.
Once we installed an NH3 evaporator above the phosphoric fertilizer reaction tanks, heated by the upcoming water vapor. The evaporator destroyed in few weeks, while a similar one had no problem in another factory. The reason was attributed to the HF content of local phosphoric acid, while that of the other factory was supposed to be in the form of SiF4.
All above concerns phosphoric acid production by dihydrate process (filter cake was gypsum). Hemihydrate process acid may theoretically contain less fluorides due to higher reaction temperature ( http://www.efma.org...ric%20Acid.pdf ), but I have no experience on it.
Edited by kkala, 11 February 2012 - 11:17 AM.
10.000 M3 Tank Cost EstimationStarted by Guest_stelu85_* , 01 Jan 2026 |
Heat Of Dilution Of Hydrogen Chloride In Hydrochloric Acid Solution (3Started by Guest_fredlan54_* , 21 Nov 2025 |
Foam System Criteria For Hc Condensate Storage TanksStarted by Guest_Haideri_* , 28 Oct 2025 |
Atmospheric Tank Vent SizingStarted by Guest_kmic_* , 30 Sep 2025 |
