Your project, interesting and challenging, needs specific knowledge that I do not have. Some useful (or not so) remarks, having visited a coal gasification plant (1969).
1. Shell Gasification Process (
http://www.escet.urj...propuesta18.pdf), gives mainly CO + H2 as product syn gas, whose cooler is the waste heat boiler reported in Statement of the Problem (SoP).
2. SoP expressions (feeds mixed in a combustion chamber
before entering the reaction zone; the heat produced
pyrolyzes the remeining hydrocarbons into gas) give the impression of thermal cracking (kinetics rather well known). Burning a small part of feed can raise temperature to 1350 oC; yet subsequent endothermic cracking shall require further combustion. I do not know whether this concept of thermal cracking, along with several simplifications, could be applicable here. Proprietary Shell's models promote CHx + 0.5O2 --> CO + 0.5xH2 (not hinted by SoP), results will be different at any case.
3. Above is based on the impression that kinetics specific for the case will not be "public domain" yet. An expert's opinion on this would be helpful. Conversion of heavy (black) petroleum products to lighter ones have much commercial interest nowadays.
4. In case of no data, an option is to address to Shell Global Solutions, Uhde, etc. Kinetics will not be disclosed, but you could obtain illustrative material, so that you can assume something about reactor size and product composition. In my student years this was common practice, but instructor was commercially oriented. SoP does not seem to have this spirit, but you still have to do a lot technical work downstream (waste heat boiler, cleaning systems, etc). The systems would not be so "compact" as in Shell's design.
5. Requirement No 3 of the design report seems to miss something. Operating factor 95% , then assumed feed composition is not complete.
6. Hopefully your supervisor is willing to help in this project, good luck!
Edited by kkala, 10 December 2011 - 02:28 PM.
