1. Once we explored the possibility of an existing gas turbine (few MW) to change its fuel from diesel to LPG (1997). The supplier clarified that the turbine could burn gaseous propane at practically same efficiency and without modification, but not gaseous butane.
This might be related to higher antiknocking ability of propane (commercial market has internal combustion engines - with spark plug - burning natural gas or propane, but not butane). However no evidence was found. 2. A heavy basic load gas turbine burns natural gas, and backup fuel is diesel. This diesel has specifications stricter than automotive diesel.
3. Above actual observations, along with
http://www.eng-tips...cfm?qid=194171 seem to create some evidence for the following.
α. A gas turbine should burn the fuel specified for it, otherwise there may be loss of efficiency or even some damage. If a change of fuel feed is planned, ask the Supplier well in advance, usually being very willing to advise consequences.
β. Gas turbines can burn a wide range of fuels, as indicated in Fig 1 of
http://www.ge-energ...te%20Paper.pdf . But a specific gas turbine cannot burn all fuels of Fig 1.
γ. Some parts of gas turbine are delicate. It is not easy to predict suitability of a new fuel to it, at least by inexperienced (like me). Heating value, Wobbe index, composition, other parameters, seem to play a role.
4. Comments or different experiences welcomed, for a better view of the topic.
Edited by kkala, 05 April 2012 - 04:43 PM.
