May I ask under what circumstances should we choose cone bottom up or cone bottom down design for tanks? Presently, I have a Mogas tank which is to be rebuilt as the tank shells are badly corroded. It had a cone bottom up design. I have heard that a cone bottom up design will reduce the effectiveness of water draw off causing high amount of water to remain in areas of the tank which cannot be removed. This will cause Mogas to be hazy in appearance. Thus a cone bottom down is preferred. However, I would like to seek your opinions/experiences here to allow me to make a better judgement to decide the tank bottom design.Thank you!
Tank Cone Bottom Up Or Down Design
Started by CHEMeng88, Jul 11 2012 08:54 AM
Posted 11 July 2012 - 08:54 AM
Posted 11 July 2012 - 12:15 PM
http://www.cheresour...k-draw-off-sump can be useful in clarifying the query.
http://www.cheresour...rude-dewatering could be useful to some extent.
I understand that cone up bottom is more common today than cone down. Construction of drainage is judged more difficult in the latter case, since the drain pipe starts from the bottom center (long drain pipe). However cone down can be applied, especially in not quite big tanks of light petroleum products (like mogas = automotive gasoline). See examples in first web reference, post No 6.
Problems of incomplete water removal in bottom up tanks with sumps have not been heard of here. Cone down bottom can also have a central sump.
Since tank in reference had been constructed with cone up bottom, it might be easier to remain so from construction view point (will foundations / sumps be new?).
Edited by kkala, 11 July 2012 - 12:23 PM.
Scrubber DesignStarted by Guest_syamsundar_menon_* , 02 Jul 2018 |
Lpg Plant DesignStarted by Guest_betulche_* , 08 Mar 2026 |
Air Separation Plant DesignStarted by Guest_adda_* , 03 Mar 2026 |
10.000 M3 Tank Cost EstimationStarted by Guest_stelu85_* , 01 Jan 2026 |
