Respected Sir,
How to liquefy only SO2 from SO2 and HCl stream ? The concentration of HCl in the the stream is 2% by mass.
What are the considerations to be made for liquefication? Apart from Critical temperature and Pressure which predict where the gas can be liquefied I do not know what parameters are to be considered.
Please suggest some relevant literature which describes separation of gases by liquefication.
I designed a packed column scrubber to remove HCl. However with a height of 2.5m and area of 0.14m2 with ceramic intalox saddles as packing material 2% HCl could be reduced to 0.1% HCl. I want to know if there are any other processes available to remove HCl completely.
Thank You
Liquefication Of So2
Started by Roger Federer, Jul 12 2012 12:37 AM
sulphur hcl liquefy gases liquefication scrubber scrubber design so2
Posted 12 July 2012 - 12:37 AM
Posted 12 July 2012 - 09:02 AM
Krishna:
I could be mistaken, but I get the impression that you are faced with a basic Unit Operations separation problem and you are wandering away from your basic scope of work. I think you have an assignment to separate out the SO2 from a mixture with HCL. Am I correct?
There is no difficulty in liquefying SO2 since its properties are as follows:
Boiling Point = 14 oF
Melting Point = -98 oF
For additional thermodynamic information on saturated SO2, refer to the attached workbook. As you can see by its thermo properties, you don’t have to invade the Cryogenic zone to obtain SO2 liquid. But if you want to read about and study Cryogenic systems then I recommend you obtain the following texts through the Internet:
- Cryogenic Heat Transfer - Randall F. Barron - Google Books
- Cryogenic Systems (Monographs on Cryogenics, No 3)
- Cryogenic systems - Randall F. Barron - Google Books
