Hi All,
Need to design a gas adsorption column for a pilot plant.The adsorbent is activated carbon & adsorbate is natural gas.
The pressure of the column will be varying from 0.1Mpa - 4Mpa.
Would be very grateful if you can send me some design tips / any references regarding to the gas adsorption column design.
Thanks,
Bhagya
Design A Gas Adsorption Column
Started by Bhagya, Aug 20 2012 06:36 AM
Posted 20 August 2012 - 06:36 AM
Posted 20 August 2012 - 07:40 AM
Bhagya,
Take a look at these documents .
Hope this helps
Hope this helps
Posted 20 August 2012 - 11:44 PM
Bhagya,
Could you share more details on this project?
What do you mean with "The pressure of the column will be varying from 0.1Mpa - 4Mpa"?
Which are the contaminants to be removed from the natural gas stream?
Are you thinking about a once-thru plant or a TSA or VSA or PSA scheme?
What is the flow you're going to consider?
Other......
Other......
Posted 22 August 2012 - 01:33 AM
Hi Breizh,
Thanks lot for the documents. it was useful.
Bhagya
Bhagya
Posted 22 August 2012 - 02:18 AM
Hi gegio
Yes, This is not a contaminant removal unit but the gas adsorption unit for methane storage.
The purpose of the design is to store bio gas in activated carbon bed.
As per the literature, the activated carbon will be adsorbed methane during the pressure from 0.1MPa to 4MPa.
Hence the unit need to be develop to that range.
Ya, this is a kind of PSA system. Here I need to store the producing bio gas from the reactor in a adsorption column.
Hope to supply the produced bio gas to the adsorption column till it pressurized to 4MPa. Since this pressure is high in value, thinking that the Freundlich Adsorption Isotherm is unable to use for the design calculations.
Do you have any experience relating to design these kind of units? Would be great if you have any suggestions regarding to this.
Bhagya
Bhagya
Posted 25 August 2012 - 10:52 PM
Bhagya,
thank you for the clarifications.
Sorry to say that I'm not able to help you since this is not a "standard" industrial application of adsorption.
![]() Scrubber DesignStarted by Guest_nasss_* , 07 Aug 2024 |
Batch Adsorption: H/d Ratio For Vessel SizingStarted by Guest_Victor_process_Engineer_* , 28 Feb 2025 |
![]() Heat Exchanger Network DesignStarted by Guest_Kakashi-01_* , 21 Feb 2025 |
