Hollow Ball Valve Cv Calculations
Posted 03 December 2012 - 04:34 AM
Thanks in advance
Posted 04 December 2012 - 03:57 AM
Posted 04 December 2012 - 07:36 AM
ALL ball valves are hollow. That is the only way you can pass fluid through or across them.
Please be specific in your description. Submit a drawing, a photo, a sketch or a reference in the internet where we can see such valve type. In the 52 years I've been an engineer in the field, I have seen just about every type of valve devised - good and bad. I don't understand your description and haven't the foggiest idea of what type or make of valve you refer to.
Posted 04 December 2012 - 10:00 AM
Sorry for the confusion- Im still a student and probably am not the confident in explaining things.
The 'hollow' ball I am referring to is ... http://files.enginee...le=AA000002.pdf
something like this ball [see url]
...As supposed to that ball having a parallel bore. I can easily calculate the pressure drop and then cv value when the valves bore is straight but when the ball is a like a shell I am having difficulty to get a precise accurate calculation.
Posted 04 December 2012 - 10:22 AM
(Source: http://www.wellball....=38&pc_parent=9)
Edited by Steve Hall, 04 December 2012 - 10:23 AM.
Posted 04 December 2012 - 10:41 AM
Posted 04 December 2012 - 10:43 AM
Posted 04 December 2012 - 02:39 PM
As Steve has stated, it is normal practice for manufacturers to supply Test-based CV values for each of their valve types and sizes. CV values, to my knowledge, are not "calculated"; they are developed from actual test data - normally with the valve 100% open (unless otherwise indicated as to how open the valve is measured at).
I don't understand how you would be calculating the CV values for valves.
Thanks to Steve, I now can see that spherical valves are being fabricated as spheres - instead of solid, drilled balls. I would suspect the CV values for this type of valve to be at least equal to that of a full bore ball valve. I am assuming that the turbulance caused by the excess space inside the sphere does not deter from the CV value of the full-flow effect of this type of valve. However, the manufacturer should be the expert on this and should be able to furnish you will all their acquired CV values for their valves.
Posted 05 December 2012 - 05:57 AM
They have cv values which come from the manufacturers but they don't belive them to be correct. So i am calculating and then later validating my calculations with testing. So obviously I will find out the cv value from testing the valves but as part of my project i am calculating/predicting the cv values.
So i was just wondering if there was a specific way to do so. But thank you for replies and I will take note of them
#10
Posted 07 January 2013 - 01:52 AM
#11
Posted 07 January 2013 - 02:46 AM
#12
Posted 07 January 2013 - 04:56 AM
Automatic Choke ValveStarted by Guest_Mudassssir011_* , 22 Jul 2025 |
