Hi All,
I have come accross "air entrainment" in cooling tower.
here I mean that :
air bubble, generated by the water falling at high velocity in the sump, are entrained in the system, via the cooling tower outlet pipe, which causes air lock and most importantly the heat exchange in one of the plate heat exchangers to be reduced.
In the cooling tower sump, There is a strainer pipes (aka anti vortex pipe) but it does not prevent the air bubble to be entrained in the system.
I need to find a solution for this. As someone come accross it.
Please note that I have been searching the internet extensively, so please refrain from sending me generic article on cooling towers.
Many thanks,
Posted 17 December 2012 - 11:02 AM
Posted 23 December 2012 - 01:07 PM
Reader should be aware that this topic is being discussed in http://www.cheresour...-water-circuit/ '> http://www.cheresour...-water-circuit/ , along with the related "Cavitation on an open condenser water circuit".
![]() Guidance On Sizing Jacketed Pipe For Glycerine CoolingStarted by Guest_Kentucky08_* , 28 Jun 2025 |
![]() What Kind Of Cooling System Should I Use To Cool Down A Jacketed MixinStarted by Guest_HollyBoni_* , 31 Jan 2025 |
Ll Extraction TowerStarted by Guest_dpunnn_* , 22 Nov 2024 |
