Pressure Drop Equations For Pipelines
#1 Ajay S. Satpute
Ajay S. Satpute
  • 177 posts
Posted 27 December 2012 - 07:25 AM
Dear all,
I have never done line sizing of PIPELINES so far. Therefore this post has come.
Taking input from internet, API etc. I have prepared an excel sheet (attached herewith) with pressure drop calculation equations. The formula have been double checked by me and I believe it should be correct. The excel answers match approximately with that of hysys output for the same set of input.
Request you all to kindly see the excel file please. I have following questions;
1. Should there be any difference in pressure drop calculation equations for PIPING and PIPELINE? I believe there should not be any. I need to confirm this please.
2. In IPS-E-PR-440 (refer http://www.cheresour...id-line-sizing/), service pipeline company equation (for pressure drop) for single phase crude oil in PIPELINE is provided. What is the basis/origin of this equation?
3. Can we use Darcy-Weichbach equation for liquids in PIPELINE?
4. Can we use Hazen-Williams equation for water in PIPELINE?
5. Similarly other equations available for PIPING (Weymouth, Panhandle, Spitzglass, Babcock, modified Darcy equation for two phase flow) are also valid for PIPELINE?
I have seen several interesting threads in this site, but I could not be satified. :(
Thanking you in advance.
Ajay
#2 markymaark
markymaark
  • 116 posts
Posted 27 December 2012 - 09:13 AM
1) No. Some Pipe equations may say a 12" line will Have "X" Pressure drop per 100ft. Then pipeline equations will have you input the pipe length.
2) Just a conversion from volumetric -> velocity
3) Yes. To get a better friction factor look at Moody Diagrams (Perry's or other sources).
4) It's empirical, so results may be drastically different if your criteria differ from theirs.
BUT. Most of all, pipe length is not just how far Start->Finish. You need to take into account Equivalent Length. That is..valves, U-Turns, etc will cause a pressure drop as well. You will need a seperate calculation to see the total Length of pipe.
Mark
#3 Santoshp9
Santoshp9
  • 61 posts
Posted 27 December 2012 - 10:10 AM
Dear Ajay,
Great work done by you in both excel sheet,
(1.Line size criteria as per different standard & 2.Pressure drop calculation equation for pipe)
Thanks.
#4 Ajay S. Satpute
Ajay S. Satpute
  • 177 posts
Posted 02 January 2013 - 06:31 AM
Thanks Mark for your reply.
Thanks Santosh for the encouragement. :)
Regards.
Ajay
#5 AVINASH UTTAM WAGH.
AVINASH UTTAM WAGH.
  • 5 posts
Posted 23 January 2013 - 02:36 AM
Thanks.
#6 katmar
katmar
  • 694 posts
Posted 25 January 2013 - 03:32 AM   Best Answer
Ajay,
Some very useful and interesting articles have been published by the Pipeline Simulation Interest Group on the comparison of various "historical" methods. Two good ones to start with are
http://www.psig.org/...s/2000/0112.pdf
http://psig.org/Papers/1980/8801.pdf
#7 Ajay S. Satpute
Ajay S. Satpute
  • 177 posts
Posted 27 January 2013 - 10:57 PM
Mr. Katmar,
Thanks a lot for those 2 great articles.
Regards.
Ajay
