Multiphase Equilibria Solid Model In Properties
multiphase equilibria solid model properties vapor liquid
7 replies to this topic
  • guestGuests
  • 0 posts
Posted 02 May 2013 - 09:04 AM
Could you give some detail about the solid model (SSM) which base version of Prode Properties adopts for multiphase equilibria ?
The documentation says it is based on liquid fugacity less contribute of molar heat of fusion but I think it is a bit more complex,
also solids in  phase  equilibria seem to work better with a EOS as Peng Robinson or Soave Redlich Kwong,
is that true ?
#2 marchem
marchem
  • 153 posts
Posted 03 May 2013 - 01:39 AM
Prode Properties has several models for solid fugacity,
with Simplified Solid Solution SSM model included in Base version
fugacity of solid phase is calculated from fugacity of liquid phase as
Fsolid = Fliquid * exp(CT*Hf/Tm - CT*(cpl-cps)-...)
where
Hf = heat of fusion
Tm = melting point
cpl = heat capacity of liquid phase
cps = heat capacity of solid phase
there are additional terms which provide some contributes
Generally I utilize the SSM (Simplified Solid Solution) model with hydrocarbons,
it's good to predict vapor-solid as for example solidification of CO2,
for liquid-solid I utilize SSM or other models.
For hydrocarbons a EOS as Soave Redlich Kwong or Peng Robinson can provide good accuracy.
#3 pdender
pdender
  • 27 posts
Posted 09 May 2013 - 05:26 AM
thanks Marchem,
what is the role (in phase equilibria) of the solid vapor pressure available in databank ?
Does Prode Properties utilize those values ?
#4 PaoloPemi
PaoloPemi
  • 550 posts
Posted 22 May 2013 - 02:57 AM
the SSM model included in Base version doesn't utilize that information,
as noted by marchem there are other models for solid fugacity
also you may extract the data from database (Prode allows direct access to all properties of pure fluids) and create your own model.
#5 pdender
pdender
  • 27 posts
Posted 30 May 2013 - 02:55 AM
thanks PaoloPemi,
so, can I calculate solid formation for a pure fluid with the solid vapor pressure available in Prode Properties databank or with SSM  (or other solid models) available in the library ?
#6 PaoloPemi
PaoloPemi
  • 550 posts
Posted 13 June 2013 - 06:35 AM
I am not sure to understand the question,
do you wish to utilize the coded flash operations in PRODE PROPERTIES (T-P, H-P, H-T etc.) with multiphase (vapor-liquid-solid) option
or create your own  procedure ?
By the way for pure fluids you can calculate solid formation with the solid vapor pressure available in Prode Properties databank,
that's not difficult since you have only to compare the solid condition with the pressure in your system.
#7 pdender
pdender
  • 27 posts
Posted 02 July 2013 - 11:16 AM
thanks Paolo !
yes, I can define the state of a (pure) fluid comparing its solid and liquid vapor pressure.
#8 PaoloPemi
PaoloPemi
  • 550 posts
Posted 15 August 2013 - 01:26 AM
also please note that you may need specific thermodynamics (as a electrolytic model) for some liquid-solid equilibria as salts formation.
