Pump Suction
height
7 replies to this topic
#1 PRkumar
PRkumar
  • 20 posts
Posted 18 May 2013 - 02:45 AM
what is the maximum suction side height we take ,when pump suck the fluid from well/vessel or other equipement?
pranav
#2 fallah
  • 5,026 posts
Posted 21 May 2013 - 06:25 AM
pranav,
Pump's NPSHR would dictate such height if other parameters, say suction vessel elevation and low low liquid level..., are to be already fixed.
#3 PRkumar
PRkumar
  • 20 posts
Posted 22 May 2013 - 02:50 AM
dear fallah sir,
                      here i am talk for pump suction lift case.(For suction lift case what is the maximum height we take?)
Ragards
pranav
#4 fallah
  • 5,026 posts
Posted 22 May 2013 - 04:10 AM
pranav,
It depends on fluid S.G. and local atmospheric pressure For water at sea level it is around 10 meters from liquid level. Then, maximum height of suction side from the liquid level:
H (m)=10/S.G
#5 breizh
  • 6,992 posts
Posted 22 May 2013 - 07:00 AM
Pranav ,
Consider these documents and you will find your answers .
I'm sure it will help .
Edited by breizh, 22 May 2013 - 07:03 AM.
#6 PRkumar
PRkumar
  • 20 posts
Posted 23 May 2013 - 04:48 AM
Dear all,
               thanks.
Best Regards
pranav
#7 SenOil
SenOil
  • 48 posts
Posted 23 May 2013 - 05:15 PM
Dear Breizh, Fallah,
im looking for how to size a pump for water transportation application, the system consist to transport  water stored in water tank to the sea the distance is 15,000 ft .the water comes from our natural gas well after being separated its like a brine; the composition of this water is close to seawater.
for more details regarding my system design see attached file
System Data
1. type of power engine
Natural gas
2. cost of energy
3. pumping lift
13.12 ft
4. pump column pipe (suction line)
3-in. steel pipe
13. distance from pump to vessel
26 ft
5. system flow rate
132 gpm
6. yearly operating time
1000 hrs
7. distance from pump to pivot
14763.78 ft 3 inch PVC pipe
8. required operating pressure
15 psi
9. elevation change from pump to pivot
+49.21 ft
10. types of fittings in system
see drawings below
11. suction vessel pressure
14.5 psi
12. minimum liquid level above pumper center line
13.12 ft
many thanks to All for your help.
#8 thorium90
thorium90
  • 1,073 posts
Posted 24 May 2013 - 02:34 AM
Do refer back to the following thread.
http://www.cheresour...sel-to-the-sea/
