I have a positive displacement electrically operated metering pump that's been dosing pretty erratically: Specs. specify a +/- 3% tolerance whereas the feed tank currently shows 25% variation (as measured between successive time periods).
What are typical items to troubleshoot?
The pump has a diaphragm coupled to a prime mover by an intermediate hydraulic fluid. Flow adjustment if by means of a manual screw and pump operates at 100 strokes per minute. Prime mover is a three phase induction motor. Pump has a pulsation damper on the discharge side and a strainer on the suction. Rated pressure is 3 barg on the discharge.
The atmospheric pressure feed tank outlet is ~4 feet above the pump suction and is connected to it by 1 inch piping of ~20 feet length. The discharge piping is also 1 inch and goes to a reactor nozzle about 30 feet above the pump discharge. The target flow rate is ~400 Litres per hour.
The fluid is 40% H2O2 at around 30 C ambient temperature.
Any tips?
