At my terminal we are Transloading from a Pressurized Railcar into a Bulkmatic Trailer. Due to the nature of the product, a food grade chicken feed additive, we are constantly leaving heels on the railcar. The product is very sensitive to humidity and will clump very easily making it all but impossible to completely empty out. The rail cars are lined so we cannot scrape the product out without damaging the railcar. We've talked about using vibrators on the railcars to possible jar it loose, but this could possibly damage the railcar as well. I was wondering if anyone has had experience with similar product that clumps easily, making it hard to empty the railcar completely. If so, have you found a solution or technique that helps minimize this. Thank you.
Dry Bulk Transloading
Started by tyk216, Jun 04 2013 08:03 AM
No replies to this topic
Posted 04 June 2013 - 08:03 AM
Bulk Residence Time In Naphtha CrackingStarted by Guest_mehul_* , 19 Oct 2018 |
Trv Or Psv For A Fuel Transloading System?Started by Guest_Reckless73_* , 27 Jan 2021 |
Simulating A Liquid Mud Plant And A Dry Bulk PlantStarted by Guest_ebi4exploit_* , 07 Aug 2018 |
Particle Size Vs Bulk DensityStarted by Guest_sateeshkumar830_* , 20 Aug 2015 |
Bulk Bleach Delivery SystemStarted by Guest_Subject_Name_Here_* , 03 Jun 2016 |
