Dear all,
Here I've attached the excel sheet for calculating the line size for gravity flow. This excel I've prepared to calculate the line size for DM water transfer from overhead storage tank to condenser. I used the basic hydraulic calculation for this. In this excel, I've data base for pipe and pipe sch data and quick drop down list to select the size and sch and options to select MOC of pipe.
With the selected pipe size, we can check whether the pipe is suitable or not. If suitable, how much pressure to be reduced in control valve also provided.
Kindly enable MACROS before using this excel.
Your comments are welcome!
Samayaraj
Edited by samayaraj, 23 February 2014 - 05:31 AM.
