I would like to size and select a pressure relief valve for an application but first need to determine the relief flow capacity for the valve. The worst case scenario is for nitrogen gas at 25 deg C exiting a HP cylinder valve which has an upstream pressure of 25000 kPag and downstream pressure of 7000 kPag. The cylinder valve size has an ID of 4mm (OD 20mm) but reduces after the cylinder valve fitting to 12mm ID. I have used two methods for calculating the flow, one is the ISA 75.01.01-2000 calculations which takes into account inlet and outlet pipe fittings and the other is a Cv calculator from the Swagelok website. Both methods give me different results, and I am unsure which method I should use to calculate the flow. At this stage I am inclined to take the worst case scenario which is that calculated from the Swagelok calculation.
Out of interest, when do you use the ISA calculations for no fittings vs with fittings considering all field applications will have pipe fittings attached?
Cheers, Ashley G.
Maximum_Flow_Calculation.doc 73.5KB
398 downloads
