Dear Art / Fallah/flarenuf,
Thanks for Your replies. I have attached a simplified sketch . As a background , Currently spheres/ bullets PSV are routed to atmosphere . Propoasl is to route them to flare header. Few spheres have ESD valves and while others have not. Upstream system detail i am trying to gather in full . But as per operation , liquid overfill have been happened in one spheres in past . So now two options are being considered :
1. Option -1 : Design the flare system considering liquid overfill may happen.
2. Option -2 : Provide SIL rated instrumentation to avoid liquid overfill in spheres.
No doubt , option -2 is recommended. But considering , option -1 , whether it would be feasible to design the safe flare system.
Below are the two scenarios:
1. Propane bullet overfill : With given composition , relief valve outlet tempertaure would be -32 deg c . And taking the heating effect ( atmospheric minimum temp is 5 deg c ) , relief stream temperature would be -9 deg c at KOD , and it would be all vapor. So for this stream , steam coil / or vaporiser would not be helpful . So steam tracing / electrical heat tracing may be required to heat 10 ton/hr propane vapor from -9 deg to + 5 deg c to avoid water freezing in seal drum. Duty requirement would be 60 KW.
2. Butane sphere overfill : Butane relief would be two phase at KOD and temperature would be -1 deg c . Butane liquid can be vaporised by existing steam coil and flared.
In attached sketch , vaporiser has been shown as optional. This could be attached to KOD or separate as required. I have seen in cold flare system ( like oleflex unit ) vaporiser attached with flare KOD .
Please advise.
