Dear experts,
Please I have two questions:
1-For varaible speed centrifugal pumps, could you confirm that there's no nedd to have minimum flow recycle and PSLL and PSHH at suction and discharge?
2-I have transfer pumps transfering water from a water storage tank to water injection pumps (installed nearby injection wellhead) via 3 km flowline. Could both pumps, transfer and injection,be variable speed pumps? The transfer pumps are controlled by the level in the tank and injection pumps are controlled by the flow in the flowline?
Please advice
Variable Speed Centrifugal Pumps
Started by asseddik, Oct 01 2014 04:46 AM
Posted 01 October 2014 - 04:46 AM
Posted 01 October 2014 - 11:21 PM
asseddick ,
1) a VSD is having the same function than a control valve i.e reduce or increase the flow rate .Of course the pump still needs to operate at a rate equal or above the minimum flow to prevent overheating and damage . You should consult vendor for the minimum flow rate or take a look at the pump data sheet.
Regarding the pump suction , it must be Flooded otherwise risk of vapor lock
Hope this helps
Hope this helps
Fan Laws For Centrifugal Compressors And Varying Suction ConditionsStarted by Guest_SickPuppy0_* , 25 Jan 2023 |
Answered
Centrifugal Compressor Performance Curves In Aspen HysesStarted by Guest_Rafcio_* , 14 Mar 2024 |
Design Gauge Pressure Inlet To A Centrifugal Compressor.Started by Guest_Mohammad3799_* , 03 Mar 2024 |
Using Vector User Variable In HysysStarted by Guest_Ulbert Zsolt_* , 01 Mar 2024 |
Variable Speed Pump CurvesStarted by Guest_panagiotis_* , 27 Jan 2024 |
