I have recently carried out some very simple pump hydraulic calculations using the standard method of first selecting the fixed pressure points of the upstream and downstream vessels, pressure controllers etc and then back back calculating the inlet/outlet pressures for the control valve on the pump discharge so that the control valve can be sized.
My problem is that one of my clients who is the Process Manager for the client company doesn't understand this concept and thinks that control valves are an instrument engineers responsibility and has nothing to do with process, but he does not understand that the instrument engineer needs input from process to size the control valve. Keeps saying that we are "completely wrong", even though this is a very simple calculation and this is the way any process engineer is going about it. The problem is that he is saying we must repeat everything done his way at our expense and there are no other process engineers in the client company with the expertise to challenge him.
My question is as follows, are there any international standards that outline the standard method of how to conduct a pump hydraulic calculation. We need a silver bullet that we can use to defend our work and avoid the large expense of having to rework everything his way. I'm also concerned that he is bad mouthing our company to other people in the industry.
