Level Gauge Radiation
8 replies to this topic
#1 trungphu
trungphu
  • 106 posts
Posted 18 March 2015 - 11:55 AM
Hi everyone,
In Snamprogetti's urea production technology, the level is measured by radiation. Could someone here explain me the reason for that?
Thanks in advance
#2 ahmadikh
ahmadikh
  • 42 posts
Posted 18 March 2015 - 01:40 PM
By radiation, do you mean guided wave radar (GWR) type level measurement?
#3 breizh
  • 6,356 posts
Posted 18 March 2015 - 06:34 PM
Consider the resource attached . I've been using this type of technology on Distillation columns .
Reason : Nature of the materials , shape of equipment .
Note : Sometimes difficult to import , safety is a concern ( management of the sources , maintenance work )
Hope this helps
Edited by breizh, 18 March 2015 - 11:13 PM.
#4 trungphu
trungphu
  • 106 posts
Posted 23 March 2015 - 08:16 AM
Thank you so much, Mr. Breizh. That's very helpful.
#5 curious_cat
curious_cat
  • 475 posts
Posted 09 April 2015 - 08:03 AM
@breizh
Out of curiosity what's their cheapest unit you've used / seen. Just trying to get  an approximate idea of the cost of this technology.
#6 breizh
  • 6,356 posts
Posted 09 April 2015 - 05:52 PM
The technology is from Berthold , continuous level monitoring on Distillation columns .The main challenge was to import this technology to China , sorry I cannot support about the cost .
#7 Teknas
Teknas
  • 22 posts
Posted 11 April 2015 - 04:25 AM   Best Answer
Radiation type level measurement is usually applied for a non-contact type level measurement, it gives high accuracy and is not affected by the density/viscosity of the fluid being measures. It is also called as Nucleonic type or Gamma type level measurement.
If possible, could you share in which equipment and what is the process fluid that is being measured by the radiation type level transmitter in your case.
#8 trungphu
trungphu
  • 106 posts
Posted 07 October 2015 - 11:23 PM
Dear Mr. Teknas,
The process fluid in my case is urea solution
#9 manojkaila
manojkaila
  • 66 posts
Posted 08 October 2015 - 08:42 AM
Dear,
I don't have much information abut urea solution. But in Fluid catalytic cracking I have seen this type of level gauge in Main column ( Distillation column) main fluid is slurry with temp around 360 C. Other location is in catalyst fine level measurement. Hope this information will help.
