Heat Loss Calculations
#1 Engineer87
Engineer87
  • Store Customers
  • 61 posts
Posted 06 August 2015 - 06:41 PM
I'm totally new in heat loss calculations.I want to calculate the time required by the oil flowing in the insulated pipeline to get cooled down to 0C.
Ambient temp is -40C
Process temp is 5C
Fluid is Oil
Insulation is mineral Wool
Thickness is 1.5inch
Wind speed is 5mph
Pipeline size is 6inch
I calculated the heat loss but still need to calculate time required by my fluid to cool down to OC.
  • 6,787 posts
Posted 06 August 2015 - 07:18 PM
Engineer 87 ,
Please don't duplicate the posts .
Go to the search engine in this forum and key in : Pipe insulation heat loss , you will find information to answer your query . You should also consider to supply more info about your process fluid ( flow rate, temperature , viscosity , density , calorific capacity ,..).
Good luck.
#3 Engineer87
Engineer87
  • Store Customers
  • 61 posts
Posted 07 August 2015 - 03:02 AM
Thanks Breizh,
Here is some more info.I did not get any post showing answer to my specific concern
Flow rate =7264bb/d
viscosity=5.6cp
Density=54lb/ft3
Temperature=5c
Edited by Engineer87, 07 August 2015 - 03:03 AM.
#4 breizh
  • 6,787 posts
Posted 07 August 2015 - 03:24 AM
Also missing the length of the pipe .
I've attached a copy of a  work done by Stephen Hall .
Edited by breizh, 07 August 2015 - 03:27 AM.
#5 Engineer87
Engineer87
  • Store Customers
  • 61 posts
Posted 07 August 2015 - 03:52 AM
Thanks Breizh,
My pipeline length is 100m.I have used this sheet but it does not tell me anything about time required to cool my liquid down or am i missing somethin?
#6 breizh
  • 6,787 posts
Posted 07 August 2015 - 06:34 AM
With the data supplied and other missing ( specific heat; thermal conductivity ) , your fluid will stay around 4.9 C at the outlet . The temperature will drop below zero  if you drop significantly  the flow rate  . If this is possible , you will need to consider tracing your line .
Hope this helps
