Gasoline Vapor Recovery Through Condensation
#gasoline #vapor #pump #vacuum #heatexchange
#1 AJ97
AJ97
  • 7 posts
Posted 06 July 2019 - 08:19 AM
Greetings,
I would really like to size a vapor recovery system using condensation as the recovery method.
Attached is the scheme of my proposed system, I would like to ask for inputs on :
- possible pumps ;
- Possible drawbacks of the system from someone who has used before and whatever you guys can help me with
Thank you
  • Attached File  VRU.PNG   31.19KB   2 downloads
#2 Bobby Strain
Posted 06 July 2019 - 04:29 PM
That's like designing a wheel. The system is widespread.
#3 breizh
  • 6,902 posts
Posted 06 July 2019 - 08:17 PM
Let you try your favorite search engine : Vapor recovery system .
#4 AJ97
AJ97
  • 7 posts
Posted 07 July 2019 - 12:31 AM
Thank you Dear sir,
This is a University assignment and the emphasis is placed on the learning experience from engaging in such an activity.
Again, thank you very much.
#5 AJ97
AJ97
  • 7 posts
Posted 07 July 2019 - 12:34 AM
Hello sir,
I have read up on the information available, I asked on this forum for more information about things that I did not antecipate or do not know.
Thank you very much
#6 breizh
  • 6,902 posts
Posted 07 July 2019 - 05:24 AM
To get a proper answer you should use the Student Forum .
To me you should install the HX (condenser) before the pump to protect the pump .BTW which technology of vacuum pump do you consider ? liquid ring or dry ?
The pump should be in contact with non condensable or a minimum quantity of organic.
My view
Edited by breizh, 07 July 2019 - 05:31 AM.
#7 AJ97
AJ97
  • 7 posts
Posted 07 July 2019 - 07:33 AM
My view
I will read the guidelines and if possible,  ask this there.
The reason why I thought about installing a vacuum pump with no condenser before it is because I've read that vacuum pumps could be capable of pumping vapor.
I am considering liquid ring pump because of lower woking temperatures.
Well using non condesable is not possible because I am proposing the use of condensation as the means to recover vapor.
Thank you for your insights
