  • Log in with Facebook Log In with Google      Sign In
  • Create Account
ChExpress Blog - 5/14/13
Read the latest news from the chemical industry in Christa's blog.
Heat Loss from Pipes
Chemical Reactor -thumb Rule For Reactor Height To Diameter
  • You cannot start a new topic
  • You cannot reply to this topic
#1 Guest_Nattu_*
Guest_Nattu_*
  • guestGuests
Posted 29 August 2007 - 12:12 PM
I would like to know if there is any general thumb rule for stirred reactor height to diameter.
#2 Geoffrey
Geoffrey
Posted 03 September 2007 - 06:17 AM
Here is a rule of thumb, that I found in a Excel workbook downloaded from the cheresources site, that has to do with drum vessels.
QUOTE
Optimum Length/Diameter ratio is usually 3, range is 2.5 to 5
Maybe it can help. I attach the workbook here.
#3 pilot
pilot
  • 11 posts
Posted 04 September 2007 - 05:14 AM
QUOTE (Geoffrey @ Sep 3 2007, 06:17 AM) <{POST_SNAPBACK}>
QUOTE
Dear this excell file is not opening, Can you re-attch, its look like havingRead only & other errors....
#4 Guest_Nattu_*
Guest_Nattu_*
  • guestGuests
Posted 04 September 2007 - 06:15 AM
Thanks Geoffey!!
#5 joker1
joker1
  • 11 posts
Posted 05 September 2007 - 04:08 PM
QUOTE (Nattu @ Aug 29 2007, 12:12 PM) <{POST_SNAPBACK}>
The L/D ratio depends on the process involved. For example for a boiling CSTR used for polymers (high viscosity) you need a low L/D (say 1:1) supplemented by a disengagement head space to avoid polymer entrainment/ add cold material to quench a runaway reaction. So you end up with L/D of 1.5-2.
Having a higher L/D may cause the agitator shaft to be beefed up.
Bottom line is you have to use engineering judgment.
