Posted 08 June 2009 - 08:19 AM
Dear Padmakar,
I have no idea of this flowsheet, so really I can not comment if there will be formation of two liquid phases in the system. But what surprises me is that you did not get satisfactory results using other Activity Coefficient Model. My approach for validating any Activity Coefficient Model would be:
1) Try to get the VLE/VLLE of major components in the system, if possible then at the temperature and pressure similar to in the process. While gathering this data, try to get as many sets of points as possible. This step may be cumbersome, but is essential to the entire exercise.
2) Using the Activity Coefficient model chosen, predict the VLE/VLLE and if the prediction is not good, then estimate the coefficients. If you have data at multiple pressure/temperature points, use the regressed coefficients to predict at least one set.
3) Once the above two steps are set, you can use the coefficients thus obtained in your simulation.
If you are using a commercial simulator, then I'd strongly suggest that you go through the above step. I'll give you a small example that I faced with ASPEN Plus. I was trying to reproduce some result of gas separation simulation which was done quite some time back in my organization. The original simulation was also done in Aspen, however, somehow we lost the simulation file. We still had the simulation results. I put in a lot of effort but could not get to match the data. Then I simulated the flowsheet in HYSYS and we got a very good match. Then people in my organization started complaining that Apen in no good for gas processing (they conveniently forgot that the original simulation was in Aspen). I took this problem and then analyzed, only to realize that the Binary Interaction Parameters for Methane and H2S were missing. And that was a big problem, because we were guaranteeing H2S slippage. When I inserted Interaction parameters, which were regressed from data in DECHEMA, we had a very good match with the ole simulation as well as actual data.
Moral of the story is that it is easy to say that some thermodynamic models are just not good enough, without understanding the issues. So always when you do your simulation understand the thermodynamic method you are selecting. Look and ensure you have all the Interaction Parameters/ Activity Coefficients beforehand. Be sure that you know the limitations of the method you are using/going to use. Also beware, Aspen had the BIP's (originally) and at some point of time they removed the BIP's for CH4/H2S from the database (and was made available in Aspen Properties, which you had to buy!!!).
Hope this clarifies few things.
Let me know of your comments/similar experiences.
abhishek
