A contract requires a compressor casing lead test to be conducted using helium as the fas medium. The test pressure requirement is 4004 psig.
Helium can be supplied to the casing from an existing source to raise the casing pressure up to 1800 psig.
Bottles of helium must be purchased from an outside source to raise the casing pressure up to 4004 psig from 1800 psig. Given the following information, how many bottles of helium must be purchased to achieve the 4004 psig requirement?
Compressor Casing volume = 10.9 cubic feet
Helium bottle compacity - 500 standard cubic feet of helium at 6000 psig
(standard conditions - 60 def F, 14.7 psia)
Molecular weight of helium = 4.01
Ambient temperature = 70 deg. F.
Compressibility of helium - assume 1.0
144PQ=MRTZ
P -pressure, Psia
Q - volume, Ft3/min
M-mass, lbs/min
R- Gas Constant (1545/mol.wt
T- Temperature, R (absolute) deg F + 459.67 = deg R
Z - compressibility
Most are given in Standard conditions but we need acutal conditions so we need to calculate them first to plug them in.
Need Help With An Answer
Started by , Apr 30 2008 01:43 PM
Posted 30 April 2008 - 01:43 PM
Posted 01 May 2008 - 06:06 AM
You say you need help with the answer. What work have you done to get the answer (besides typing out the problem)? What, specifically, do you need help on?
What is "contract requires a compressor casing lead test to be conducted using helium as the fas medium" and what does it mean?
Are you saying that you have a fixed volume that you are filling with two sources of gas pressure?
Posted 02 May 2008 - 07:32 AM
Yes the volume is 10.9 cubic feet and I am filling with the exsisting source and also and outside sorece. I need to figure out how many bottles to buy.
Posted 02 May 2008 - 08:24 AM
Buy 4 cylinders of HP Helium.
Posted 02 May 2008 - 08:57 AM
QUOTE (Art Montemayor @ May 2 2008, 09:24 AM) <{POST_SNAPBACK}>
Thank you for your reply. I would like to understand how you got it. I need more of the thinking process than the answer so I can understand. If you get a chance can you explain how you got it?
Posted 02 May 2008 - 10:32 AM
I got the answer by using the gas law equation:
PV = ZN RT
N = Number of Mols
You know the rest of the symbology.
It took me about 7 minutes to do it; you can time it yourself when you work it (actually the answer was 3.2 cylinders).
PV = ZN RT
N = Number of Mols
Dynamic System- Transfer Function Equations Answer CheckStarted by Guest_Ceng67_* , 30 Nov 2014 |
Some Question And What Is The Answer ?Started by Guest_aliy2k4u_* , 21 Apr 2011 |
/2 Years No AnswerStarted by Guest_CTPAX_* , 22 Dec 2009 |
Please Answer My QuestionsStarted by Guest_Engineers Are The Best_* , 09 Oct 2008 |
Please Answer UrgentlyStarted by Guest_Engineers Are The Best_* , 17 Dec 2007 |
