What is the difference between tanks , vessels & drums. One thing comes to my mind is the storage capacity tanks have much larger storage capacity , second is vessel & third is drum. Are there other differences ?
Difference Between Tanks, Vesels & Drums
Started by ayan_dg, Jun 08 2008 11:17 PM
Posted 08 June 2008 - 11:17 PM
Posted 09 June 2008 - 06:39 AM
Ayan:
I would not waste any time lingering on semantics. The important thing to always bear in mind is that there are Pressure Vessels (a generic term) and atmospheric vessels.
The pressure vessels are of major importance because, as an engineer, you are responsible for protecting the public against a rupture due to over-pressure or process upset. However, the atmospheric vessels - especially storage tanks - can be hazardous to humans as well.
Reactors are a special breed of pressure vessels because they can generate their own pressure and are also susceptible to run-away reactions. They therefore require specific and careful control mechanisms and operations.
Boilers and direct-fired heaters are still another special variety of pressure vessels. There are special codes that deal with them because of the special problems they present.
Posted 14 June 2008 - 09:22 AM
hi!
u forgot barrel?
in ur previous post (regd. pipe & tube) u have left out duct.(sorry its not u, its anil panchal)
goodday
srt
u forgot barrel?
goodday
srt
![]() Storage Tanks Diked Area Fire Protection Using Foam MakerStarted by Guest_mkhattaby_* , 30 Jan 2025 |
![]() N2 Blanketing To Gasoline Tanks With IfrStarted by Guest_NICOLAST_* , 20 Dec 2024 |
Ethylene Tanks Cctv For Leak DetectionStarted by Guest_DarthJamming_* , 30 May 2024 |
![]() What Is The Difference Between Api 521 Sixth Edition & Seventh EdiStarted by Guest_Murtaza Lashkerwala_* , 13 May 2024 |
![]() Condensate Storage Tanks In-Breathing And Out-BreathingStarted by Guest_MethanolPlant_* , 26 Apr 2024 |
