Hi chemical expert,
I'm trying to get the hydrocarbons' phase diagram. This is to enhance my understanding on when the ethane for example will be transformed into gas phase at given pressure and temperature.
You guys out there must be expert and read a lot as compared with the beginner like me. Really appreciate if somebody could copy me to the suitable link for the information.
cheers Pal.
Properties Diagram
Started by ishams, Jun 10 2008 09:56 AM
Posted 10 June 2008 - 09:56 AM
Posted 10 June 2008 - 10:15 AM
Ishams:
Reading doesn't make an "expert". First-hand results and knowledge do.
To obtain a phase diagram for ethane - such as a Mollier diagram or a "T-S" diagram, you can use one of two sources that I know of:
1) The GPSA Engineering Databook gives you detailed diagrams of the major hydrocarbon compounds - especially ethane;
2) The NIST database (free on the Internet) will give you a tabulated listing of all the properties of saturated Ethane. To find out the URL for the NIST database, use the SEARCH feature on our Forums and you will find it in one of my threads.
I hope this helps you get what you want.
Posted 02 July 2008 - 10:05 AM
Hi again Jedi,
It's me again with a new question to you. What will happen to CO2, H2S named offgas for AGRU system prior to emit to atmosphere. Specifically, if could clarify the chemical reaction for typical incinerator would be useful for me.
Thanks to you
Thanks to you
Posted 02 July 2008 - 11:43 AM
If you have a new question, start a new thread topic.
The answer to your question is that most of the time it will be routed to a Sulfur Recovery Unit, sometimes to acid gas injection. There are other processes available but these are the major ones.
Posted 02 July 2008 - 07:08 PM
As indicated by Joerd, route to Sulfur Recovery Unit (SRU) for Sulphur production while route acid gas injection (AGI) is mainly for well disposal.
Of course, another common disposal is route to (Regenerative) Thermal Oxidizer (RTO) for component breaking and disposal-off in atmosphere.
Aspen Hysys - Creating A New Component And Defining PropertiesStarted by Guest_catiiiii_* , 22 Apr 2024 |
Mtbe Process Flow Diagram Master Thesis.Started by Guest_sayoub_* , 15 Feb 2024 |
Question Distillation Column Transport PropertiesStarted by Guest_panagiotis_* , 05 Apr 2023 |
Manual Creating New Component And Setting Properties In HysysStarted by Guest_Platonicus_* , 15 Mar 2023 |
Question Properties In Aspen PlusStarted by Guest_panagiotis_* , 23 Mar 2023 |
