Whether bypass valve should be Socket welded or flanged one? Also tell, is there any requirement of upsteam & downstream pipe spool piece (between valve & run pipe ) or not.
PME
Valve
Started by PME, Oct 20 2008 01:08 AM
Posted 20 October 2008 - 01:08 AM
Posted 21 October 2008 - 01:36 PM
QUOTE (PME @ Oct 19 2008, 10:08 PM) <{POST_SNAPBACK}>
PME,
If you're asking whether a bypass valve should be socket welded or flanged, then the answer is that it should match what is specified in the piping specification. That may be socket welded, screwed, flanged, or otherwise connected. The method chosen should depend on the pressure, temperature, materials of construction, valve/pipe size, and various other factors. There is no requirement for any up/downstream spool pieces under normal circumstances.
Wafer Check ValveStarted by Guest_Ali4269278331_* , 24 Apr 2024 |
Can Anyone Provide Me The Reference Datasheet For Deluge Valve?Started by Guest_Radha Krishnan Siva Kumar_* , 16 Apr 2024 |
Valve Cv InputsStarted by Guest_QuantumEng_* , 01 Apr 2024 |
Pressure Control Valve Issues For Gsw LinesStarted by Guest_fahadazh_* , 29 Mar 2024 |
Self Actuated Pressure Reducing ValveStarted by Guest_panagiotis_* , 16 Feb 2024 |
