hey how do i find the boiling point of a crude stream in hysys
Boiling Point
Started by Clayton, Oct 22 2008 03:00 PM
Posted 22 October 2008 - 03:00 PM
Posted 23 October 2008 - 01:13 AM
Once when you have crude assay/blend installed in the main flowsheet, you can use Boilin Point Curves utility to calculate/plot various boiling point curves for you. Different standard methods are available.
You can find the same results within the Oil Manager environment once when you finalize the oil characterization procedure.
Posted 24 October 2008 - 11:59 AM
Thank you very much
Posted 27 October 2008 - 02:13 AM
Once your fluid is well defined in HYSYS, you may easily get the bubble point at Pressure by setting the Vapor Fraction to 0.
Hydrocarbon Dew Point Control UnitStarted by Guest_BabRafiq1_* , 05 Apr 2024 |
Heat Required For Boiling Liquid MixturesStarted by Guest_halkeshhulk_* , 07 Oct 2023 |
Increasing Raw Natural Gas Dew PointStarted by Guest_lowrentstuff_* , 18 Sep 2023 |
Dew Point Margin In Strippers & Fractionation ColumnsStarted by Guest_Venkat @89_* , 05 Sep 2023 |
Hydrocarbon Dew Point Control Using Propane Refrigeration Loop.Started by Guest_BabRafiq1_* , 10 Jul 2023 |
