Beneficiation Plant (phosphate)
Posted 15 June 2009 - 02:24 AM
i am HGA process engineer . currently I am working beneficiation plant .The plant is in its feed phase .i want to know more about phosphate beneficiation plant process .starting from crushing ,comminution ,floatation cell up to storage stage .
it is my pleasure to receive your comments and reply especially from who working in the same field or from people they can direct me to right place to get this type of information .
Thanks all
HGA
anazihg@gmail.com
Posted 26 August 2011 - 07:42 PM
thanks....
chem.eengineer@gmail.com
Posted 27 August 2011 - 03:30 PM
It is assumed that phosphate beneficiation in question occurs in the mine. Beneficiation process seems to be depending on the specific phosphate rock. E.g. http://www.efma.org/.../EFMABATPHO.pdf says: "Most phosphate ores have to be concentrated or beneficiated before they can be used or sold on the international phosphate market. Different techniques may be used at the beneficiation stage, to treat the same ore for removal of the gangue and associated impurities. This gives rise to further variations in the finished ore concentrate product. Phosphoric acid technology, having to rely on raw materials of great variety, has to readapt itself constantly."
I do not have knowledge on "phosphate beneficiation" , but googling this title will reveal rather usefull information, e.g. http://www1.fipr.sta...5256F790066A89A . Specific pilot tests may be required after a general knowledge on the subject. Removing sand and clay can be the first stage, then floatation is a way for further increase of P2O5. But floatation requires proper grinding in advance, see froth flotation at http://en.wikipedia....otation_process.
Edited by kkala, 28 August 2011 - 01:35 AM.
Posted 21 June 2012 - 08:41 PM
feel free to write me at fabianbenaventea@gmail.com
Grtz to all.
Posted 21 June 2012 - 08:50 PM
Hi, i like to know more about the plant design of a phosphoric acid plant, I hope you can share some info and maybe give me some tips to the structuration of my project (plant design of phosphoric acid plant production).Having worked in a NPK fertilizer plant for almost 6 years, we used several phosphate types for 30% P2O5 phosphoric acid production (Taiba, Gafsa, Maroc) , without any thought of beneficiation ever. We only installed a Raymond mill for phosphate fine grinding, which was economically justified by the increase in P2O5 recovery in the reactor (say from 96% to 96.3%, in 1978). But the feed of ground and screened phosphate should be well mixed before the phosphoric acid reactor. Gypsum was disposed of as a byproduct, yet later was accumulated within the factory (no place for disposal).
thanks in advance
Posted 22 June 2012 - 02:04 AM
The dihydrate process was used (producing gypsum, CaSO4.2H2O), which was common at that time. A single reactor kept phosphate in suspension (liquid phase was H2SO4, H2O, H3PO4) through strong agitation through several vertical agitators mounted on reactor ceiling. Temperature of suspension was held constant at 78-80 oC to ensure dihydrate. Cooling was obtained by passing air from the surface of reactor liquid, which was scrubbed after that to remove HF / SiF4 and then went to atmosphere. Resulting slurry was transmitted to two rotary filters (each with numerous invertable buckets), where the slurry was "sucked" under vacuum to take the acid, then washed with water finally going to the reactor. Filter cake in the form of gypsum (probably 1.5 t / t Taiba) was rejected onto the ground near the factory, but further disposal was a problem. Trucks transported it to valleys (landfill material), but in about 2000 I was informed that it got stacked and accumulated near the factory because no disposal area could be found (the factory shut down in 2007).
The classical book was "Phosphoric Acid" Vol 1 and 2 by A V Slack (Marcel Dekker, 1968), that we had available in the factory. I think it is still useful, even though hemihydrate processes (producing CaSO4.1/2H2O) are common today. Slack also refers to the latter, probably less extensively than dihydrate. I assume you speak about a hemihydrate process. A good book on the subject (like Slack's) seems necessary to me for the Plant Design of a phosphoric acid unit. Cost estimates are not usually included in such technical books though. Main issue is to chose technology and reactor, at that time other local phosphoric acid (dihydrate) plants had four reactors in series, or flash cooling of slurry.
Involved in Operations, then in measuring gaseous effluents to prepare a bid for treatment, I had not enough time to go into design issues. However a good book can supply a lot of such data (that I could not recall or had no chance to observe). Placing "phosphoric acid" in the search engine of this forum, you will meet sporadic information that can be also useful. For instance data about phosphoric acid tanks (rubber lined), agitation, etc.
Besides it is noted that the reactor tank was internally covered with antiacid rubber and bricks. Agitators and pumps were made of stainless steel equivalent to 304L or 316L.
Edited by kkala, 22 June 2012 - 02:17 AM.
Posted 22 June 2012 - 09:42 PM
Knowing your experience in NPK fertilizer plant and in phosphate rock processing. I would like to know about Processing phosphate rock to Red Phosphorus. Thank you.
Posted 23 June 2012 - 12:34 AM
Posted 24 June 2012 - 02:46 AM
#10
Posted 24 June 2012 - 03:39 AM
![]() ![]() Syngas Plant SimulationStarted by Guest_kaidlut_* , 28 Jun 2025 |
Urea PlantStarted by Guest_MLGP_* , 20 Apr 2025 |
Variables That Affect Energy Consumption Of Methanol PlantStarted by Guest_mobody_* , 15 May 2024 |
