I have been tasked with collating a spreadsheet regarding dispersion from an orifice and there is a large table of substances which the ratio of specific heats will be required. Does anyone know where I can find a comprehensive list of the ratio of the specific heats, or failing that a comprehensive list of the specific heat capcity at constant volume and pressure
Ratio Of Specific Heats
Started by Guest_rywo_*, Jul 03 2009 10:45 AM
#1 Guest_rywo_*
Posted 03 July 2009 - 10:45 AM
Posted 03 July 2009 - 11:59 AM
rywo:
You have failed to tell us the identities of the fluids you are dealing with. Help yourself by helping those trying to help you. If you are not SPECIFIC, how can you expect us to be?
You can obtain free, recognized, and reliable thermodynamic data (including Cp and Cv values) at the following website:
http://webbook.nist.gov/chemistry/
If you use the SEARCH feature on our Forums, you can read about this website through the years that we have been recommending it.
Good luck; and BE SPECIFIC in your queries.
Posted 03 July 2009 - 08:51 PM
rwyo:
This article in the online Citizendium encyclopedia includes the specific heat ratios, at various temperatures, for about a dozen of the more common gases:
Specific Heat Ratio
It also includes quite a bit of additional, useful information about specific heat ratios.
Specific Heat Ratio
#4 Guest_rywo_*
Posted 06 July 2009 - 05:51 AM
Sorry for not being specific, should I list the three hundred or more substances that I am dealing with?
I am new to using this forum, so soryy to offend whilst trying to find help.
Thanks for the website, I will use the search feature in future.
Posted 07 July 2009 - 01:22 AM
QUOTE (rywo @ Jul 6 2009, 05:51 AM) <{POST_SNAPBACK}>
rywo,
check the spreadsheet posted at the following link:
http://www.cheresour...x...901&hl=heat
Hope this helps.
Ratio Heat To ElectricalStarted by Guest_panagiotis_* , 02 Dec 2023 |
Split Flow Between Two Pipes At RatioStarted by Guest_Abiodun1_* , 30 Oct 2023 |
Condensate Gas Ratio (Cgr) CalculationStarted by Guest_Mohamed_Mamdouh_* , 14 Aug 2023 |
Sulphuric Acid & Water Mixing Heats. Is It A Typo ErrorStarted by Guest_IonCube_* , 24 Jun 2023 |
