Fpso- Gas Processing
#1 ROTATOR
ROTATOR
Posted 21 November 2009 - 10:53 PM
I need to find information on the use of Screw Compressors for FLASH GAS on a FPSO Topside, situated in typhoon waters of Hs 10m?
What type of compressor is best suited fpor this application?
#2 Erwin APRIANDI
Erwin APRIANDI
  • 241 posts
Posted 23 August 2010 - 01:29 AM
ROTATOR,
can you be more specific, like what is the upstream and downstream equipment,
suction and discharge pressure and what fluid to be handle and at what flowrate.
since the selection of compressor type is not as that simple
we have to see all the aspect to be able to answer yu correctly
and screw compressor is mostly use for low flowrate but high differential pressure
