Hi everybody,
Anyone has an idea how to calculate the coking temperature for the hydrocarbon gas? I need your assistance ASAP.
Thanks in advance
Coking Temperature
Started by , Dec 29 2009 12:09 PM
Posted 29 December 2009 - 12:09 PM
Posted 30 December 2009 - 09:56 AM
Hi everybody,
Thanks in advance
Dear
What is significance of coking of Hydrocarbon Gas (?). Are you looking for the cracking/coking temeprature of the crude oil.
Posted 03 January 2010 - 12:28 PM
W. L. Nelson (Petroleum Refinery Engineering, 4th ed, 1958) gives info on the matter of coking.
Concerning hydrocarbons heated in tubes:
-coking is encountered for temperatures above 820 0F = 438 0C (p. 687)
-coking results from cracking process, if residence time is (too) long (p. 679)
-cracking normally occurs above 680 0F = 360 0C (p. 663); yet extent of cracking between 680-820 0F is small(p. 674).
-operating pressure has some influence on cracking (p. 676), no info detected for coking.
-coking increases in two phase flows of hydrocarbons, unless whole fluid is almost homogeneous -i.e. high velocity or pressure>350 psig (p. 665)
-Among propane, butane, gasoline, crude oil, undergone cracking at 800 0C, crude oil creates much more coke (p. 714).
Systematic method of calculating coking temperature was not found.
Answer would be more specific and probably easier, if question were specific (conditions of hydrocarbon gas, composition, purpose).
Flowing Temperature- PsvStarted by Guest_stu_* , 17 Feb 2025 |
![]() Temperature PredictionStarted by Guest_paul_ohoir_* , 10 Jan 2025 |
Fire Relief Case - Relieving TemperatureStarted by Guest_alexzo1990_* , 06 Nov 2024 |
