Drying And Flooding Of Tray In Distillation Column
Posted 10 March 2010 - 07:40 AM
I would really like to ask you guy, whoever could clarify please, about the phenomenon in the distillation column. I wonder that is it necessary to have flooding and drying in the lower tray present simultaneously. Is it possible to have drying tray, no liquid in that tray all, without flooding on the upper trays. And lastly, if the drying occurred, what would be the effect?
Thx for all your assistances.
This is necessary for me to go through this subject.
Thx sincerely again.
Posted 10 March 2010 - 11:00 AM
Hi there,
Which tray is dry and which tray is in flooding condition, elaborate your question bit more.
Cheers
Toor
Posted 11 March 2010 - 04:06 AM
Hi there,
Cheers
Toor
I mean in general. I would like some explanation.
1. During the operation of the column, flooding may occur. Once the flooding occurs, suppose in 7th tray of the 18-trayed distillation column (counting from bottom to top), is it necessary to have drying, no liquid, on 6th tray.
2. Can the drying of tray occur without prevalent flooding phenomenon?
3. Whenever any trays have been drying, what would be the effect?
I could specify as this, no more. I have no practical example because I felt doubtful when I read the books.
That's very kind of you.
Thank a bunch.
Posted 11 March 2010 - 11:06 AM
In the event of hydraulic flood (high liquid rates), choking of the downcomer can cause dry-out of trays below as well. I've seen this scenario on several occasions in high pressure fractionators. There was cycling in tower operation, i.e. when liquid level on the tray during flooding exceeds certain value the liquid will simply dump through the tray and cause bottom level to rise suddenly. And then the cycle repeats.
2. Yes it can, particularly at extremely low liquid rates and high vapor rates (e.g. absorber in TEG dehydration unit).
3. Complete loss of separation, product off-spec. What more do we need?
Posted 15 March 2010 - 07:41 AM
Hi there,
Cheers
Toor
Thank a bunch.
1- Strat from btm, 1~18, you mentioned tray 7 Flooding and effect on tray 6; Yes Tray could be Dry, high velocity of vapors will be the main cuase and this could be due to high feed temperature or failure of condencer.
2- Yes this could be and denpend on feed composition and feed temperature and reflex.
3- Production will be off spec.
Hope this will help you.
Cheers
Toor.
