Vapour Pressure Of Sour Water
Posted 17 March 2010 - 04:28 AM
We are having cavitation issues with our sour water stripper reflux pump. The available NPSH is sufficiently (12 feet) higher than the required NPSH (5 feet) at 180°F. However we are currently operating at a higher temperature of 225°F and I am trying to determine the vapour pressure of the pumped liquid for the NPSH calculations. Can anyone help me determine this value? Not having readily available tables, I thought about using PROII with GPSA thermodynamic model, but not sure if it is accurately taking into account the H2S + NH3 equilibrium - can I use a simple flash vessel at bubble point, and vary inlet pressure until the outlet liquid comes out at 225°F?
Composition of the fluid is: 1.5% H2S, 2% NH3, 96.5% water; all mol%.
Appreciate the help.
Posted 17 March 2010 - 10:07 AM
Hello All,
KGTPE,
Considering Sour-PR package in HYSYS (recommended package for simulation of sour water stripper), the vapor pressure corresponding to 225 F for the given composition is 4.13 bar (abs).
Hope this helps.
Posted 17 March 2010 - 10:43 AM
Posted 17 March 2010 - 07:45 PM
Zauberberg, not by intent, we're having issues with our overhead cooler.
Posted 29 April 2010 - 07:46 PM
Posted 14 May 2010 - 08:38 AM
Posted 14 May 2010 - 10:27 PM
Pdrum = Pvap = vapor pressure of the reflux stream
Pstatic = static head
Pdrop = friction loss in the suction pipe
So, the NPSHa = Pstatic - Pdrop and your cavitation issues likely result from excessive inlet line pressure drop. Either you are having a lot more flow than designed, or a restriction in the inlet line. I am not sure what the temperature does to NPSHr for the pump, that may also play a role.
![]() Rupture Disc Failure Well Below Max PressureStarted by Guest_vaibhav02_* , Yesterday, 04:22 AM |
![]() Recommended Installation Location For "pressure High" InterlocStarted by Guest_omupei_* , 20 Jun 2025 |
