Can anyone tell me where I can obtain data on the calorific value, specific heat capacity and latent heat of vaporization of Diesel, Bunker C and LPG?
Various Data Needed
Started by Guest_zili_*, Feb 07 2005 05:32 AM
Guest_zili_*
Posted 07 February 2005 - 05:32 AM
Posted 07 February 2005 - 08:39 PM
Zili:
I want to emphasize that Diesel oils and Bunker C fuel oils are mixtures of many, many different hydrocarbons. Therefore, different diesel oils derived from various crude oils and from various refineries will have somewhat different physical properties.
I also want to emphasize that LPG from various refineries will have various compositions. Some LPG may be primarily propane, some may be primarily normal butane, some may contain isobutane, and some may be mixtures of propane, and butane, isobutane. Since you did not provide the compositon of the LPG, I will give you the properties of pure propane and pure butane.
Finally, I want to point out that the specific heats and specific gravities will vary with the temperature of these fuels. Also, the net heating values will be about 92% of the gross heating values.
Diesel Oil::
Liquid specific heat @ 60 °F = 0.50 Btu/lb/°F
Heat of vaporization = 140 Btu/lb = 1010 Btu/gallon
Gross heating value = 19,250 Btu/lb = 139,000 Btu/gallon
Specific gravity @ 60 °F =0.8654
Bunker C fuel oil (also known as #6 fuel oil):
Liquid specific heat @ 60 °F = 0.45 Btu/lb/°F
Heat of vaporization = 95 Btu/lb = 782 Btu/gallon
Gross heating value = 18,230 Btu/lb = 150,000 Btu/gallon
Specific gravity @ 60 °F =0.9861
Propane:
Liquid specific heat @ 60 °F = 0.59 Btu/lb/°F
Liquid heat of vaporization = 185 Btu/lb = 784 Btu/gallon @ normal boiling point
Liquid gross heating value = 21,480 Btu/lb = 91,030 Btu/gallon
Specific gravity @ 60 °F =0.508
Gas specific heat @ 60 °F = 0.39 Btu/lb/°F
Gas gross heating value = 2,500 Btu/ft3 @ 60 °F and 1 atmosphere
Butane:
Liquid specific heat @ 60 °F = 0.56 Btu/lb/°F
Liquid heat of vaporization = 167 Btu/lb = 814 Btu/gallon @ normal boiling point
Liquid gross heating value = 21,120 Btu/lb = 102,930 Btu/gallon
Specific gravity @ 60 °F =0.584
Gas gross heating value = 3,230 Btu/ft3 @ 60 °F and 1 atmosphere
Sources of above data were:
"Perry's Chemical Engineers' Handbook"
"Data Book on Hydrocarbons", J.B. Maxwell, published 1950 by D. Van Nostrand, Inc.
"Phillips 66 Reference Data for Hydrocarbons", Bulletin 521, Phillips Petroleum, 1962
Diesel Oil::
Propane:
Butane:
Co2 And Mea Vle DataStarted by Guest_Verdurer_* , 24 Mar 2025 |
![]() Equilibrium Data For Nitric Acid And WaterStarted by Guest_ksagarzazu_* , 07 Oct 2024 |
Help Using The Data Fits Tool In Aspen HysysStarted by Guest_catia_* , 14 Jun 2024 |
Aspen Edr Error Data BaseStarted by Guest_adrich91_* , 31 Jan 2024 |
