hi chemical engineers .... i need some help .... iam doing a project on syngas production and iam simulating it on hysys i need to know which fluid package to use my doctor said i must use ntrl put i have an absorber using a solvent selexol which i think dont agree wiz ntrl an error appear saying some of the binary cooficients are unkonow and will be set to zero plzzzzzzzzzzzz i neeed help ??????
Steam Methane Reforming
Started by eng:snow, Mar 22 2010 08:32 AM
Posted 22 March 2010 - 08:32 AM
Posted 25 March 2010 - 12:45 AM
Dear:
you can check the components in the syngas, my suggestion is using RK-SOAVE in Aspen plus, using PR in HYSYS.
Best wishes.
Best wishes.
Posted 25 March 2010 - 01:49 AM
HYSYS example from the library uses Peng-Robinson equation of state.
By the way, simulating Selexol unit in HYSYS does not give quite reliable results.
Posted 29 April 2012 - 02:22 PM
in the name of god
بسم الله الرحمن الرحيم
بنام خداوند بخشاينده مهربان
you can't simulate the steam methane reformer furnace by general software like ASPEN PLUS, HYSYS, PRO II becuse this reaction is a kinetic reaction and needs length of reactor, catalyst material, catalyst shape and burner conditions(TOP FIRED, TRACED WALL,...).
if you have conversion of this reaction you can simulate this furnace by hysys, aspen, pro ii, chemcad but it is very simple and you can get only the duty and the outlet composition without any information about furnace.you can do this by RIPI_REFSIM.
for CO2 absorption in the tower you can't simulate this process by recent hysys. you can do this by hysys version 3.0.1 or 3.1 and using OLI electrolit package but using aspen plus and ELENRTL with HENRY'S LAW for CO2 is very beter than hysys and using PRO II by AMSIM package is best(AMSIM is a madul that it is added in PRO II version 8.0 and later)
Converting Superheated Steam To Saturated SteamStarted by Guest_addiesalsabil_* , 10 Sep 2023 |
![]() Steam Used In ReboilersStarted by Guest_aliebrahem17_* , 05 Jul 2025 |
Steam On Shell Side Of A Vertical HexStarted by Guest_Lyne_* , 09 Jul 2025 |
