Tube Metal Temperature Distribution Using Chemcad
Started by sdahidi, Mar 27 2010 06:53 PM
Posted 27 March 2010 - 06:53 PM
Could you please advice how I can get a curve/table for the tube metal temperature along the tube length for Shell & Tube Heat Exchanger using ChemCad. I build the rating model for Air Preheater installed within boiler package we have and with ChemCad sucessfully obtained tube & shell side temperatures at different zones, the simulation calculated also the mean metal temperature along the whole tube length.
Appreciate any help in this regard, i need to check the metal temperature along the tube length to check if it is enough above the dew point temperature of sulfuric acid to avoid corrosion.
Thanks in advance for your assistance.
Sami
Sami
Posted 28 March 2010 - 03:39 AM
The first place to check for metal temperature is cold-end of an exchanger.
If this is a BWF-Flue Gas exchanger, you can safely assume that the cold-end metal temperature is equal to the BFW inlet temperature. In other words, the tube metal at the inlet of BFW to the exchanger will be at the same temperature as Boiler Feed Water, and this is due to the fact that the resistance for heat transfer between liquid and metal is fairly small. Therefore if you want to eliminate cold-end corrosion, you have to ensure that BFW inlet temperature is about 5-10C higher than the calculated acid gas (sulfuric acid) dew point temperature.
Also read more at: http://v_ganapathy.t...m/corrosion.pdf
Posted 28 March 2010 - 03:57 AM
For calculating tube metal temperatures, refer to the following pages from "Process Heat Transfer" by D.Q.Kern.
Posted 29 March 2010 - 02:55 AM
I know it is not exactly your question, but if you are interested by the detailed tube temperature, why not use an rigorous shell & Tube modelisation tools like HTFS - Aspen EDR or HTRI ? These should be able to answer your question. This is of course if your company has access to one of them
Posted 29 March 2010 - 03:16 AM
Good point - but there's no need for rigorous modeling in this particular application. The fact is that the flue gas will definitely reach BFW inlet temperature (and experience localized condensation if the temperature is below Acid dew point).
Modeling would be interesting for gas-to-gas exchanger application, however a fairly good results can be obtained by Kern's method as well.
Smr Reformer Tube Hot BandStarted by Guest_kaidlut_* , 07 Aug 2025 |
![]() Pipe Fluid Temperature Increase Due To Solar LoadingStarted by Guest_HeemeshJ126_* , 06 Apr 2016 |
