Distillation Column Diameter Feasibility
  • guestGuests
  • 0 posts
Posted 01 April 2010 - 09:17 AM
Hello, I have come to the stage where I have sized the top of the distillation column to be 3.5 meters in diameter. I have been looking around industrial sizes and so far i have seen 2-2.5 meters diameter max hence im starting to think that my calculated diameter is industrially unfeasible.
I think it is because of the large amount of load in the trays (rectifying section: vapour flowrate of 70 kg/s, 5 m3/s, liquid flowrate of 22 kg/s, 0.02m3/s). Or am i just being naive? Cheers!
#2 Zauberberg
Zauberberg
  • 2,728 posts
Posted 01 April 2010 - 09:33 AM
Hello Lee
Do not worry, the diameter of Amine Absorber in the plant where I work now is 7,000mm. Design pressure 84 barg.
The biggest diameter tower I have seen so far was located in one petroleum refinery - Vacuum tower of 8,100mm DIA.
So just keep on moving - 3,500mm is just fine.
Cheers,
  • guestGuests
  • 0 posts
Posted 01 April 2010 - 09:45 AM
Hello Lee
Cheers,
thanks a lot! That is very reassuring since I have no first hand experience in industry whatsoever, great to hear it from someone with experience. Thanks again!
#4 riven
riven
  • 178 posts
Posted 06 April 2010 - 01:54 AM
To add
If you look up data on ethylbenzene styrene purification (will take time on google) you will often see columns specified for vacuum service, structured packing and 5m in diameter. I would say the range you quyote is probably the limit of 'commodity' design; I tend to think of columns as being a worldwide commodity.
#5 abhi_agrawa
abhi_agrawa
  • 216 posts
Posted 06 April 2010 - 07:37 PM
LeeFauxe,
just to add to the list I know of C3 splitter in a petrochemical plant with diameter more than 8000 mm and Gasoline Fractionator more than 10,000 mm.
abhishek
  • guestGuests
  • 0 posts
Posted 08 April 2010 - 08:59 PM
To add
Thanks guys, this has really reinforced my concept of size especially in real world industrial applications. I've just found a picture of a tray where two men are stood beside it, the diameter was easily around 10 meters! :D
