Liquid Holdup Capacity Pumps
Posted 18 April 2010 - 07:42 AM
Posted 18 April 2010 - 08:56 AM
Apparently a buffer drum at pumps suction is needed, to reduce consequences of flow variation that could cause even pump cavitation. Instead of placing such a buffer drum, 8" pipe has increased to 20" and then again to 8". So pipe section of height H and dia of 20" makes the required buffer tank to smooth flow to pumps. The note actually advises to maximize H, thus liquid hold up volume of said drum.Hi all - There is a tower overhead stream of vapor entering a condenser (quite a bit of elevation above grade), condensing and then going down to a set of pumps. The piping between the exchanger and pump looks like this: exits exchanger as 8", expands to 20", then back to 8" to enter pump. There is a note by the 24" section that says to locate the pumps below the exchangers and to route the 20" vertical run to maximize the liquid holdup capacity of the pumps? I was wondering if anyone could explain what this means to me. Thanks!
Edited by kkala, 18 April 2010 - 08:59 AM.
Posted 18 April 2010 - 10:35 AM
Posted 18 April 2010 - 10:46 AM
Posted 18 April 2010 - 04:16 PM
Suppose that H=5 m, the tube of 20" is half full (that is h=2.5 m) and suddenly flow from condenser increases by 1 m3/h.kkala - thanks for that. How does a "buffer drum" prevent flow variation?
Volume of buffer drum is about 1 m3, so it can accept increased flow for 30 min before the liquid approaches condenser. If pump flow increases by 1 m3/h, liquid level of buffer drum will come to pump suction (risk of cavitation) after 30 min.
If first disturbance occurs for 20 min and next for 10 min, operation will not be disturbed; only liquid level will be some 2.5*(20/30-10/30)= 0.83 m higher, that is h=3.33 m.
In this way flow disturbances can offset each other. Result is more effective if flow is regulated by some level control (e.g. LCV at pump discharge linked with LIC at the buffer tank of H=5m dia=20").
Posted 23 April 2010 - 02:53 PM
Isenthalpic Throttling With Flashing LiquidStarted by Guest_lofarcio_* , 06 May 2022 |
