I was checking the datasheets for a deethanizer column and its reflux drum which you can see in the attached file. the MDMT for reflux drum is -80°C however, MDMT for the Deethanizer column is determined as -48°C. why there is this difference when the same liquid in the reflux drum flows back into the column?
Minimum Design Metal Temperature
Posted 01 May 2010 - 02:04 AM
Posted 01 May 2010 - 04:16 AM
MDMT has nothing to do with the service. but its determined according to the material of construction from ASME VIII UG-20 . so probably they are not made from same material.
Posted 01 May 2010 - 09:49 AM
Sorry but I think I am a little bit confused. So, what is the temperature for which we run a dynamic depressurization to determine it? isn't it MDMT? or it's the minimum design tempreture?
Posted 01 May 2010 - 12:26 PM
Dynamic depressurization determines MDMT and MDT (minimum design temperature) would be MDMT minus the margin value as per relevant process sizing criteria.
Difference between MDMT of Deethanizer column and relevant Reflux drum isn't confusing because each one would be depressurized through its own BDV while has been isolated from another one and different peak flowrates of depressurization leaded to different MDMT in those equipment.
Posted 01 May 2010 - 01:04 PM
Fallah,
Better to determine Process parameter for coincident temp and then go for MDMT because MDMT is not giving you worst case design guide lines.
Cheers
Posted 02 May 2010 - 02:09 AM
Fallah,
Cheers
Toor,
About the equipment operating at a temperature below 0.0 degree of centigrade you are right,but normally for equipment operating above 0.0 degree of centigrade MDMT gives worst case design guidelines.
![]() Pipe Fluid Temperature Increase Due To Solar LoadingStarted by Guest_HeemeshJ126_* , 06 Apr 2016 |
![]() Hello, Design Of Natural Gas Liquefaction Processes.Started by Guest_guoyinyanliner_* , 18 Jun 2025 |
