Pipeline Refrigeration Issues
Posted 02 May 2010 - 12:39 PM
I am in the upstream operations field. I have a small issue with a couple of lines coming into my facility here and I am certain that it is not a hydrate as there is 24.72 mmscf/d flowing through this 8" line. I have been hunting for a while to find an exact chemistry equation to give me a proper leg to stand on when I take this to the engineers. They don't see a problem here, but what works on paper, doesn't always work in practice. The volume of gas is fairly consistant as above, but from the header system to the facility, it goes from roughly +10 C to -5C in the inlet separator. All fluid from the wells needs to go into the flow line at the well level as access is very restricted. At the header, 3km away, the pressure is 1675 kPa and at the inlet is 975 kPa. I have been hard pressed to try and find concrete proof for the engineers.
HELP, please.
Thanks.
Posted 02 May 2010 - 01:54 PM
If there is a hydrate formation issue, most likely you would see the line gradually plugged by time and the flow would certainly decline over time.
Temperature drop for the given pressure drop seems to be too high though, but without knowing your concerns/problems in particular, we can't be of more help. Can you give us a more detailed description of what is the actual problem you are faced with?
Posted 03 May 2010 - 12:55 PM
Posted 04 May 2010 - 01:16 AM
Please take a look at the scheme uploaded below and confirm if this corresponds to the actual field layout. Do the necessary modifications, and add the twin 8" pipeline that you are proposing.
Speaking without knowing other details, it seems to be that a lot of liquid flashing takes place across the pipeline, causing high pressure drop (2 bar/km) due to increased flow velocities. The system is definitely below hydrate formation temperature so I hope water is not present in the wellstream. The actual 7 bar pressure drop - assuming pure gas flow, no liquids - cannot cause temperature drop of 15 degC due to Joule-Thomson effect. An approximate figure/guideline for J-T effect is ~1 degC for each 2bar pressure drop, if I remember well. So the normal arrival temperature should be in the range of 6-7degC assuming adiabatic flow.
Your reasoning is correct in my opinion, simply because there are flow limits for any given size of pipeline. Trying to pull more production will cause pressure drop to increase, which increases amount of flashing, which further increases pressure drop, and so on. It's really hard to give any other suggestion since we dont't know anything about production stream quality and other details of the production system (e.g. like ambient heat transfer - it can have a huge effect on the flow in 3km long pipeline). If you are interested in sizing of production piping system, grab a copy of API 14E. Although it covers offshore production platforms originally, it is equally applicable for onshore facilities as well.
Posted 04 May 2010 - 04:20 AM
Do you control the pressure in the receiver section, or it is controlled somewhere upstream?
What we have here is a cluster of 33 offshore wells distributed between 3 platforms, with the production fluid flowing through the two identical pipelines in parallel. The pressure is controlled in the onshore Inlet Reception facilities (79 barg), while the pressure in the offshore test separators is somewhere around 100-105 barg. The pipelines are 38km long.
It would be good if we could know the exact description of your system - that way we can be of most help.
Posted 11 May 2010 - 09:52 AM
Posted 11 May 2010 - 10:00 AM
That's right on the money. Flow rate on the upstream 8" is roughly 9/16 of the 25 mmscf/d flow rate. The 6" is 1/4 and the 4" that ties into the riser system is the remainder (1/16).Ops,
Psv For Refrigeration SystemStarted by Guest_runnerup_* , 30 Jun 2025 |
Determining Pipeline Design PressureStarted by Guest_applepe_* , 05 Dec 2024 |
Energy Saving In Pump By Reducing Pressure Drop In Downstream PipelineStarted by Guest_Srinivas Agastheeswaran_* , 19 Nov 2024 |
Steam Condensate Pipeline Water HammerStarted by Guest_kaidlut_* , 06 Sep 2024 |
Achieving Ultra-Low Water Content (<0.1 Ppmv) For Pipeline PiggingStarted by Guest_Finchh_* , 21 Aug 2024 |
