Dear all,
Need help for simulating Butadiene extractive distillation plant.
Currently, I am working on Extraction of 1,3-Butadiene from C4 cut (other components varies from C3's to C5's) extractive distillation by using a solvent consists of Acetonitrile, Ethanol, Water, NaNO2, P-TERT-BUTYLCATECHOL (TBC).
Here NaNO2 is acting as inhibitor and TBC is for prevention of popcorn reaction and composition of NaNO2, TBC in Solvent is as low as 400ppmw. As I am totally new to this process, Can anyone tell me is it needed to take these components (NaNO2, TBC) while doing simulation in Aspen Plus?
Fluid property package is changing from NRTL to ELECNRTL because of these components.
I would like to know if anyone has worked on this.
Any help is appreciable.
Pavan.
1,3 Butadiene Extraction
Started by kpavan, May 14 2010 12:14 AM
Posted 14 May 2010 - 12:14 AM
Posted 17 May 2010 - 03:33 AM
I would suggest that Aspen will not be able to simulate these quantities or compounds. It is better to lump these compounds to their appropriate key components (either heavy or light). You can still take care of them in the mass balance.
That is unless you are specifically looking at simulating the reactions that these compounds prevent in which case I cannot help you.
Posted 14 June 2010 - 04:07 AM
Dear,
Fisrt let me know which simulator you are using if hysys then use Wilson FP (activity coefficient model) provided you don't have VLLE and just have VLE.
Posted 16 June 2010 - 02:01 AM
Thanks for your reply.
Padmakar,
I am using Aspen Plus as simulator for doing this.
And as the system is extractive distillation which consists of solvent and hydrocarbons, so I think this should be VLLE. Please correct me if I am wrong.
Please let me know if any other data is required.
Pavan
Padmakar,
Pavan
Prv Vs Extraction Condensing TurbineStarted by Guest_mj311_* , 13 Nov 2024 |
Ll Extraction TowerStarted by Guest_dpunnn_* , 22 Nov 2024 |
![]() Butadiene StorageStarted by Guest_Mirzazada_* , 27 Mar 2021 |
Ll Extraction: Equilibrium Stages Calculation With Matlab CodeStarted by Guest_MGFX70_* , 14 Apr 2022 |
Best Practices For Extraction Of Amines From Wood TarStarted by Guest_quantum31_* , 19 Jun 2023 |
