Distillation-Pervaporation. Transfer Data From Hysys To Matlab And Vic
Posted 18 May 2010 - 07:27 AM
I am having a big problem. I'm working with a dynamic simulation of a hybrid distillation (batch column and membrane pervaporazione) with hysys. For the distillation batch I made a PFD hysys, but to simulate the dynamic pervaporazione I thought of writing a program in matlab!!
how can I transfer the data flow of distillate (composition and flow) from hysys to matlab and vice versa.
thanks in advance
p.s. sorry for my bad english
Posted 18 May 2010 - 09:44 AM
i'm desperate.............help me!!!!!!!!!!!
thanks in advance
I am sure you could use a compiler but that would be time consuming.
What is the application? For example if the pervaporation part is producing 2 pure products (i.e. pure ethanol (i.e. 99.5wt%) on feed and pure water (99%) on permeate) then you simply use the two programs to find the optimum conditions first with the column and then with the membrane. The water in that case can be sent to waste water treatment.
Posted 18 May 2010 - 01:59 PM
in my case the membrane is used for the purification of ethyl acetate from water. water will permeate, while the fraction rich in ethyl acetate should be feed back into the column as reflux !!!!!!!!!!!!
thanks in advance
The simulation of the batch column is made with hysys while I thought to simulate dynamic pervaporation with matlab !!!!!!!
can you have any suggestions to simulate the dynamic pervaporation in hysys??
thanks in advance!!!!!!!!
p.s sorry for my english
Posted 19 May 2010 - 03:31 AM
What I would suggest is this:
- Fix the outlet from the top of your column using your top stream as the reflux; if ethyl lactate and water form a low boiling azeotrope this will be done for you.
- Model the top stream separation in the pervaporation model.
- Rebuild your simulation in hysis and instead of using your top as the reflux as a new feed stream with the composition gained from the pervaporation model.
See if you can get the results from 1 and 3 to line up.
Edited by riven, 19 May 2010 - 03:32 AM.
Posted 20 May 2010 - 10:54 AM
thanks in advance!!!!!!!!!!!
Posted 20 May 2010 - 09:05 PM
Organic Peroxide Distillation IssueStarted by Guest_Kimbreaux_* , 19 Feb 2026 |
Short Path Distillation Rotor SpeedStarted by Guest_MEC_* , 11 May 2023 |
